Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II LSN1000JQ0
The washer runs through all cyles well, including rinse and spin until the last spin cycle. The motor is working and and the lid switch works fine. I put a screwdriver to hold the switch and spun the basket and it began to spin normally, sometimes. .It does this on all cycles ,Delicate ,Heavy etc. Any suggestions?
  • 1 more comment
  • dvizian Jan 25, 2009
    how do you replace the agitator, it keeps slipping through the wash cycle. Thanks
  • Michael Grimshaw May 11, 2010
    Is the clutch slipping? You can test this with the basket empty, start a spin cycle, and with a wet hand you should not easily be able to stop the basket from spining.
  • Ian Greenland May 11, 2010
    not sure what you are asking.
    Novelist:
  • 131 Answers
If you're pushing the masket to get it moving, it's definitely oil on the clutch. Call Sears for a Service Smart Agreement. Tell them it pumps out but doesn't spin. They'll replace the transmission, clutch, and motor coupler (a $400.00 job) for about $250.00. Or, maybe it's (sadly) time for a new machine.
Remember to click on Fixya!
Posted on Mar 17, 2008
    Sergeant:
  • 351 Answers
Is the drive block under the agitator broken
Posted on Mar 12, 2008
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II will not go into rinse or spin cycle. Motor runs and agitates during wash cycle properly. This problem occurrs on all wash cycles.
The problem is most likely with the lid switch. This washer can fill and agitate with the lid up or down but will only drain and spin with the lid down. If the lid switch breaks the washer does not know that the lid is down so it will not run.
The part number for your model is 8054980 and runs about $20.00, it is shown in the image on this link below as part 11.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0403060-00001.png
Apr 20, 2010 | Whirlpool Ultimate Care II GSQ9669L Top...
Wont drain burning smell
if it smells electrical then it is the motor and just because you replaced it months a go that dont meen anything i have seen them come off the shelf and be bad not saying ddty that this is your issue but it sounds like it a bad solinoid chances are very slim I would look towards the motor to find out when machine quits lean machine back on the wall so it dont fall on you and put your hand on the motor if it is hot then it is over heating and needs to be changedplease let me know what you guys find and if i can help you in any way
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSQ9669LGO
Sounds like you may need to replace the timmer
Jun 06, 2006 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
741 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
