Question about Sony Playstation 3 (PS3) Console
PS3 Surround SOund
Just got PS3, I connected the HDMI from PS3 to HD tv, I then connected an optical audio from PS3 to my Yamaha 3000bl sound bar / receiver....when i play a blu-ray, it does not play in stereo / surround.
sorry dont have any ps3 games yet...please HELP!!!
  • ciawarrior Mar 08, 2008
    audio setting on the Ps3 or the surround sound?
  • ciawarrior Mar 09, 2008
    I fixed it, just had to change audio to optical cable, It was a long day.
Go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Posted on Mar 08, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
144 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
