Question about Motorola Mobility C168 Cellular Phone
Making the alarm a PM?
I just got this phone, my sister has had it for a few weeks, I've looked through the manual and searched online...is there a way to distinguish between an AM and a PM alarm??
Thanks
Okay, I was playing around with it last night and you have to enter the time as military time?.  So if you want an alarm for 11pm, put in 23:00. etc.
Posted on Mar 08, 2008
LG441 tracfone, how to set alarm
Tap the Settings icon (four squares), tap the Alarm icon, tap New Alarm, set the time and am/pm, set the day of week, set the tone and volume and any other desired options, then tap Save.
If you need a manual, you may download a copy from http://www.lg.com/us/support-mobile/lg-LG441G
Nov 27, 2016 | LG Cell Phones
LG441G how to set alarm
Samsung Galaxy S4--Alarm Clock Issue
Take it back and get your money back as there is obviously a problem with that unit. Try a different brand.
May 23, 2013 | Samsung Cell Phones
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    How do i change the alarm time from pm to am? its not in the manuel.
    http://www.lg.com/us/mobile-phones/LG-GT365-Aqua-Blue.jsp
    Above is a link to your phones manual in case you ever need it if you lose the one that you have.
    Time: Select the desired set time mode
    using the navigation key. Input your desired
    alarm time by specifying the hour and
    minutes. If the time is in the 12 hour format,
    you have to select either 'am' or 'pm' using
    the Center key.(its just your select key)
    (Repeat: Select the desired repeat mode
    using the navigation key.)
    Alarm Type: Allows you to choose an
    Alarm type for your selected alarm.
    Options are: Follow Profile/ Always Sound/
    Always Vibrate.
    Alarm Tone: Select the alarm sound to use
    for the alarm using the Center key
    This is actually found on page 65 of your manual.
    I hope this helps you out. just select the format, am, pm or 24 hours like you would the time you want to change the hour or mins, .
    I hope this helps you. please let me know
    May 14, 2011 | LG Neon GT365 Cell Phone
    How do I change the radio station on the radio alarm
    Here is the full manual
    http://www.timexaudio.com/pdf/T311IB57574_35.pdf
    Here are the instructions from the manual.
    Setting the Radio Alarm
    1. Press and hold the
    Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
    appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
    flashing and you will need to press the
    Radio Alarm Button again.
    2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
    for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
    3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
    to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
    information on programming radio stations into memory, see the Programming Radio Station Settings section
    of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
    4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
    lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
    the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
    While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
    5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
    Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
    Aug 08, 2009 | Timex T311T Clock Radio
    Alarm clock
    Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
    Mar 25, 2009 | Motorola Mobility I335 Cellular Phone
    Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
    try looking up the manual on the model number you might find it online. I have the maual for this model.
    Jun 10, 2008 | Audio Players & Recorders
    Setting the Alarm
    After you set the time on your alarm, if the icon out to the side of it is am & you want pm, press the - button on the very top left hand corner & it will switch to pm. Vice Versa if the icon out to the side is pm & you want am
    Jan 11, 2008 | Pantech C120 Cellular Phone
    Motorola Mobility C168 Cellular Phone Logo
    51 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
