Question about Dirt Devil Vacuums
Dirt Devil 085845 . Sucks the rug up
085845 dirt devil. says on vaccum that it is automatic height adjust. This baby sits so tight to the floor that it will pull a 3 foot long rubber back rug right up the vaccum and stall the motor. Called Dirt Devil and they told me to lean handel back 45 degrees and let motor run until I heard a motor pitch change and it was set. My motor dont change pitch with handel held at any degree angle even after a minute of holding. Called them back and they said that not all models do that and I need to take to authorized repair. I have had it all apart and back together and I dont see anything that could lower the wheels. There is a plastic cam that forces the wheels down when sweeper handel is put into the upright position for storage or to use the hose attachment. But otherwise when the handel is down those wheeles just flop down and are loose with nothing to power them down or hold them down. Thanks for any help. Bud
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Posted on Feb 28, 2008
  • 126 Answers
SOURCE: Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Posted on Mar 30, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Posted on Jun 24, 2008
Dirt devil breeze bagless height adjustment mafunction
Hi there! If your vacuum is suddenly hard to push your roller lifter assembly, which controls the automatic height adjustment, may be damaged or broken. Check your roller lifter assembly located underneath your unit for damages. Also, your brushes help to maneuver through carpet, check that your brushes are still spinning. If not, replace the belt on your vacuum. I have included a link where you may visit to purchase a replacement belt for your vacuum. Hope this helps!
Style 4
Aug 08, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil platinum force no longer pushes easily
Hi there! If your vacuum is suddenly hard to push this could be an indication that your belt that controls your brushes has broken. The brush roll helps to maneuver through carpet. Check that the brushes are still spinning. If the brushes are not spinning you will need to take the vacuum in to a Dirt Devil authorized service center to have the belt replaced.
There are also two small wheels underneath the vacuum that controls the automatic height adjustment. Inspect the height adjustment cam, shaft and wheels for damages.
Below is a link where you may go to locate the nearest service center to you. Hope this was helpful! If you require further assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Service Center Locator
May 01, 2014 | Dirt Devil M091200 Platinum Force Upright...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Brush on vacum wont make contact with rug, no pick up
if you take off the brush then reorientate the ends of the brush this will adjust height ends have a block depending on orientation they will set brush height This is common for many brush assemblies and should work for dirt devil
Jan 16, 2009 | Dirt Devil Vacuums
Dirt devil en vision
Jun 15, 2008 | Dirt Devil CE5500 Floor Keeper Upright...
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
467 people viewed this question
Top Dirt Devil Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
