I connected my 30 gig ipod to my sharp 5 disc shelf stereo. it connects with a usb.. now my ipod will not shutoff or pause.. itunes does not recognize that an ipod is connected.. i have not connected anything to the stereo in quite some time and the last time that i did, ( my ipod shuffle) it said no media.. help????!!!!!
  • 42 Answers
Make sure that your shelf stereo in IPOD ready most unit need a bridge of some sort or a dock. If your receiver is ready and it is not working still then the problem is in the multi media device.
Posted on Mar 08, 2008
ITunes will not recognize my Ipod MA444LL
There are many reasons why iTunes will not recognize your iPod, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPod you have, here are a few suggestions for helping the problem of iTunes not recognizing iPod:
  1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
  2. If you are running iTunes in the latest version, but still can't get your iPod recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
  3. USB port on your computer can be another reason why iPod not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
  4. Of course, your iPod may also be the cause of iTunes not recognizing iPod. At this moment, you can restart your iPod by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPod to computer with USB cable again.
  5. You should also make sure your iPod trusts your computer, because after changing a new system on computer, your iPod will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
  6. After checking out all the aspects mentioned above, you can try to connect iPod to computer with the USB cable again.
What to Do When iTunes Not Recognizing iPhone
Dec 21, 2011 | Apple iPod Audio Players & Recorders
Is there some way to connect an ipod to a Philips mc-m570 stereo?
the interface will probably only work with the phillips software, but many of those stereos support playing from a flash drive.
Oct 20, 2011 | Philips MCM570 CD Shelf System
How to shut down the Ipod 30 GIg' I was downloading Itunes to my Ipod and my itunes program said that it could not download any Itunes to the Ipod. The Ipod is running and I cannot shut it down
itunes is downloaded and installed on your computer.
not onto you ipod.
once itunes is installed on your computer, open the program and connect your ipod to the computer via usb cable.
It will mount to itunes and then just learn how to use it and load your music.
Jun 20, 2010 | Apple iPod MA446LL/A MP3 Player
30 gig ipod is frozen. Hard reset doesn't work.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode
http://support.apple.com/kb/HT1363
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod
(ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are:
Restore Option
1: Restore - Restores with same iPod Software version already on iPod.
Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option
3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed,
iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display.
It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to
name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 21, 2009 | Apple iPod MA446LL/A MP3 Player
I have an ipod classic with 20 gig. When I attempt to restore it it to original settings I get unknown error 1439. What can I do to get it to work again?
Symptoms When restoring or updating an iPod in iTunes 7 or later, I'm guessing you got a message saying an unknown error occurred 1469
ResolutionIf you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
  • Restart your computer without the iPod connected. While it is restarting, you will need to force your ipod into disc mode.
  • Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  • When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  • Now, with the ipod in disc mode attempt to restore.
  • If that does not resolve your issue, try connecting your iPod to a different USB port and then attempt to restore.
  • If after all these steps you still have not been able to successfully restore your ipod, I would recommend going to:
  • http://support.apple.com/kb/TS1539
Follow the steps posted by apple in the solution number one box. I had this issue once and was able to resolve it with that article. If for some reason this does not resolve your issue please do let me know.
Mar 13, 2009 | Apple iPod classic MP3 Player
It said connect to power
hi :) uhmm, try to press the menu button and the center button at the same time. this happened to first ipod, a nano also, and it worked. hope this helps :) and i know how you feel emily , teehee :)
Sep 14, 2008 | Apple iPod nano
Ipod 30 gig 5th generaiton question
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 06, 2008 | Apple iPod nano
30 gb ipod not connecting to computer.
If nobody has figured out this problem or if anybody else is having the same problem I have a solution that could possibly work. I had the same problem so I right clicked My Computer and went to Properties. Click on the Hardware tab, and then click on Device Manager. Scroll down to Universal Serial Bus controllers look for anything that may have a yellow exclamation point. Mine said something like Apple Ipod Driver or something along those lines. Right click that and click Update Driver... Then click Next and it should update it for you and work fine. Hopefully this will help anybody that is having this problem.
Jan 24, 2008 | Apple iPod MA446LL/A MP3 Player
Mp3/iPod compatible connection
hi , instade of going thru USB, just plug a stereo RC pin to the Headphone socket of the iPod and the other RC connectors to the line in of the stereo system, play the Ipod, u can now hear it from ur steroe system.let me know
Jan 02, 2008 | RCA RS2664 Shelf System
IPod Battery
You should try using a different USB cable and connecting to a different USB port and seeing if the problem persists. If it does, the problem's probably with the iPod's logic board.
Jan 01, 2008 | Apple iPod MA446LL/A MP3 Player
83 people viewed this question
 Grubhead
Grubhead
