Tried to hook up our
I tried to hook up our tv to a digital video recorder box today and it didn't work at all....now the t.v has a blue screen and the prior box doesn't even work......PLEASE HELP!!!!!!!!
  • 99 Answers
First check your tv,if has a digital input or your digital video,has a analog output. and try to connect it from anolog out from your video to analog input to your t.v or from digital out to digital input of your tv. another one is the type of system you are using.it should be compatible to your system,example: your digital video is ntsc,then your t.v should have a ntsc system also.
Posted on Mar 08, 2008
  • 42 Answers
It sounds like you need to switch back to the original input on the TV the one that you would have been playing your DVR through is receiving no signal therfor no prev. CH
I HAVE DISH NETWORK AND WANT TO CONNECT MY NEW ZV427MG9 A UP TO RECORD A SHOW, ON DVD. MY TV HAS RCA CONECTIONS IN THE FRONT, BUT I HAVE TO BE ON VIDO 4 TO USE THOSE. MY DISH BOX HAS A SET IN THE BACK, I...
you need to hook the dvd recorder up to the dish net work, yellow to yellow port, red to red port, and white to white port.
the dvd recorder should have had a book in with it to show you how to hook it up
Mar 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
16 bit mega drive sega cord splits into 2 with small switchon it
insert the yellow jack to the tv yellow jack and insert the red jack to the tv red jack
Oct 08, 2009 | Sega Genesis Console
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Digital converter box hook up
Can you describe how the DVD and VCR were connected prior to the converter box when they were working? I need to know that in order to guide you properly.
Thanks,
Dan
Jul 24, 2008 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
