How to install hp 2420 on network - Televison & Video
  • 93 Answers
First Configure IP Address on Printer and make sure all Other PCs are in same IP range.
Now goto Computer on which you want to install Printer. Insert CD and start Installation. It will Ask for Installation Mode You Must Select " Network" means your printer is connected to network. then HP installation will find printer in network automatically. and install.
Option 2 :
In control panel , printer and faxes
clik add printer, select network printer, select create TCP IP Port ; give IP address of printer, click next and slect printe driver. it will install printer.
Posted on Mar 11, 2010
SOURCE:
EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
May 19, 2009 | HP LaserJet 2420 Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
Hp laserjet 2420
What you need is the 2400 series software you can download it by clicking here.
Just select your operating system and then select your download and install it.Thanks for choosing fixya.com and if you have any problems let me know.
Sincerely,
Michael Scott
Apr 20, 2009 | HP LaserJet 2420 Printer
How to set up an HP to a NW directly
Yes, you can connect your printer to your network by plugging it into a hub, switch or router that is connected to your network.
The general HP site for your printer is here.
The Network manual is a little bit convoluted, but helpful. It is here.
You might have to re-install the printer software, which you'll find on the same page (first link). It is usually the biggest download you can find. Don't we all love HP...;-)
If you need any further assistance, please come back and I am happy to help.
Jan 11, 2009 | HP LaserJet 2420 Printer
My HP LJ 2420 printer always lost network connection
fatuto,
I would recommend replacing the JetDirect card in your printer. What model is the card? The 600, 610 and 615 can be replaced with a newer 620. Make note of all of the IP address info before replacing the JetDirect card. If you send more detailed info, I can make sure that I send the correct info that you need.
Try this and let me know what happens. Binary Bob
Oct 29, 2008 | HP LaserJet 2420 Printer
HP 2420 PRINTER
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Just fill in the printer information, and OS and it will take you to the correct download.
Aug 02, 2008 | HP LaserJet 2420 Printer
HP 2420 Issue
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Jul 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printing trouble
I think that Odyssey user is right it maybe that the print driver is not compatible with the program you are using goto hp.com or hp.co.uk and download the PCL 5e driver
Hope this helps you
Thanks J
Jan 03, 2008 | HP LaserJet 2420 Printer
Televison & Video Logo
609 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
