Question about Motorola Mobility RAZR V3
Broke the battery progs can i be fixed - Motorola Mobility RAZR V3
    Brigadier General:
  • 7,752 Answers
Yes it can be fixed it need to be heat off then a new one needs to be resoldered, so take the phone to a mobile service center or mobile tech and have them fx the phone.
Posted on Mar 27, 2008
Transmission failsafe
from your brief description i would say your alternator has failed, which means the car can no longer recharge the battery or supply battery to the car itself.
Dec 21, 2017 | BMW Cars & Trucks
I replaced my 2001 Range Rover battery and my radio stopped working. I have the code but no option to put in the code. Please let me know the steps.
most of radio need time to back to re-program , keep radio On for 40 mint or more this depend on how many time you try before , when it's on don't touch it until screan dislay (0000,) then you can re- prog. some moudle have buttom (prog. or search) after re-prog. most if you keep on for awhile it will come back by it self in programing .
Jul 12, 2011 | 2000 Land Rover Range Rover
How do you set the time as well as the timer? I have looked but can not find the manual.
Good Afternoon,
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
Feb 23, 2011 | Krups FME2 Coffee Maker
I have problems with my.zanussiprofessional dishwasher! the message c8 displays. can i fix it my self?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
Feb 10, 2011 | Dishwashers
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
How to reset unicom 51152
After inserting battery, press "000" then PROG.Enter your new 1-6 digit code and press PROG again.
To programme the alarm timing, press PROG then press:-
1 for 30seconds alarm 2 cycles, 20 seconds rest in between.
2 for 60seconds alarm 2 cycles, 30 seconds rest in between.
3 for 90seconds alarm 2 cycles, 30 seconds rest in between.
any more you wanna know let me know.
Tonybeatty@hotmail.com
Feb 03, 2010 | Kitchen Appliances - Others
Registry issues
Unless you are really up to speed with registry jargon, when using reg cleaners, yes they do a good job, but because various progs interact with each other, to save space some progs use other progs data, so what happens you remove what the reg cleaner says is u/s bits/bytes in fact are infact required to run another program.
I think you can unstand this has happen to me and not just once, this is experience and lost progs.
If you really must then make sure you backup all important data to external hdd, before reg cleaning, least then you will have important data to access when you reinstall setup progs. Good Luck.
Nov 10, 2009 | Computers & Internet
No monitor
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN or DON'T
5) START IT UP...
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE.Hope that will do. Otherwise you can re-install windows if you have a Windows CD.That will definitely solve the problem.There might be problems with VGA Resolution [if you have used the laptop with some other monitor or TV] or driver. For installing Windows Do Google Search.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Holding voltage for car radio in a workshop
Certainly a car radio with a digital tuner must have a permanently live supply to the memory. A PP3 might do the trick but it might have a limited life and prove costly. Try it and see.
Personally I would use a car battery that is no longer fit for car engine starting but good enough to run a radio. Most car-owning folk have a car battery charger tucked away somewhere to keep recharging the battery, even better a small solar panel costs little and will maintain the battery.
I fitted a "scrap" battery to my caravan several years ago and installed a £10 solar panel and the caravan light still runs fine with the same battery.
Nov 18, 2017 | Blaupunkt DVD-MER
I have spyware i scanned my computer the result of the scann show 1 entery in my way my web ser i wnat to fix the problem but ican please tell me what to do
spybot search and destroy prog. download/    run prog (isolate....then delete)
download....no more cookies....clean daily (easy)
Dec 21, 2008 | Computers & Internet
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
