Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis WTL lint indicator problem.
The lint indicator signal keeps beeping. I cleaned the lint filter, cleaned the heat exchanger, cleaned the interior dryer of lint and water. I'm unsure of where the air inlet is so that I can check it. Everything else is cleaned and it is leaking water from the left side underneath. Pump has been replaced already about 6 months ago. It was found to be defective. Can anyone offer a solution?
  • Anonymous Mar 16, 2014
    lint indicator blinks then turns off and dryer will not start even though I cleaned the lint trap
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Posted on Apr 20, 2008
What I found is that I needed to thoroughly clean the dryer filter with soap and water. Over time, the tiny holes in the mesh get clogged and it hinders the air flow. The filter itself should be lily-white, like a pair of white nylons (sorry, best example I could think of.) I estimate it will need this thorough cleaning about once every 6 months or so (more often if you run your machine more than average.)
Posted on Mar 29, 2008
As one other solution suggested, run water over your filter. If it pools, the filter is clogged (even if it looks fine). I ran some soap over it with a qtip, and seconds later the water was going straight through. And so far, no lint filter alarm!
Posted on May 24, 2012
    Sergeant:
  • 351 Answers
It may be a sensor fault,most dryer inlets are from the back.if the internal ducts are blocked it can cause this broblem,sometimes the drain hose from the pump can get a hair ball stuck in them.you may have to dismantle the dryer to find the solution.hope this helps.
Posted on Mar 08, 2008
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
After every load, the dryer lint trap is wet and there's water condensation on inside of the glass door even days after use. I've thoroughly cleaned the ducts and the lint filter as well as inside where...
Is it gas dryer?
If it is might be problem with the heat exchanger, Water is one of the by products of combustion.
By chance do you have a Carbon Monoxide sensor?
Easy way to tell if a cracked heat exchanger is the problem.
Other thought I have is the dryer heating up when its drying, if the heater isn't working and you are throwing wet clothes in there that could be part of the issue.
a couple thoughts anyways
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Kenmore 7.3 cu. ft. Electric Dryer w/...
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
Dryer has no heat--even though lint filter and heat exchanger are clean; the light is also off, but the tumbler turns normally
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Nov 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
623 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
