Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44360 thermostat wiring
I currently have a Von Air digital non-programmable thermostat controlling my Trane electic a/c and heater. Where do I put the wires on a programmable Hunter 44360. Original connections are as follows:
Orange to O/W2
Red to R, Yellow to Y/Y2, Green to G, Blue to C and White to W/W1. The new tstat does not have the connection letters and seems that I have too many wires to connect. CAN ANYONE HELP????
  • 2 more comments
  • Anonymous Jun 06, 2008
    Yeah, my husband is trying to figure this out at this very moment! I was hoping to find some help! =)
  • bjohnston Jun 15, 2008
    I have attempting to replace White-Rodgers (WR) Heat Pump Themostat (non-programmable) with Hunter's (H) 44360. I have Payne Heating and Cooling Heat Pump Model: PH10JA042-B
    I have made the following connections and nothing works:
    WR G connected to H G
    O " " " Y/O
    R " " " RH (I disconnected jumper to RC)
    Y " " " Y1
    W2 " " " W/B (WR had jumper wire to E)
    There is a brown wire available not used by WR.
  • mlc3530b Oct 19, 2008
    I have the same problem. The A/C side works just fine. However, when we tried the heat for the first time this morninig it would not shut off. Any suggestions?
  • rodney969 Oct 29, 2008
    I installed the Hunter 44360 last
    spring. The A/C has worked all summer. When switched to heat the heater runs
    continuously. It will not shut off at the set temperature.
I bought the hunter 44360 programmable thermostat also, and have the same problem with the heat not shutting off. I recently took off the face plate and started looking at the switchess on the back. Look for a switch that has the option "std" or "hp". I flipped the switch to the "std" position and my therrmostat has been working great in heating my home.
hope this helps,
rich
Posted on Nov 18, 2008
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Posted on Nov 14, 2008
LOL I'm having the same problem with the same 44360.
Posted on May 03, 2008
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermo smoked when elec. turned on
Where are the wires connected in the heater ? They should be on R and W, if the W is on C you are shorting the heat anticipator in the thermostat. If the unit is wired right look for a spot where the wire is rubbed thru and touching the metal housing of the heater.
Aug 22, 2009 | Hunter 30124 Air Conditioner
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have an old janitrol thermostat with terminals marked R,Y,G,O,W2 and I want to replace it with a Hunter 44360 Programmable Thermostat with terminals marked G,RC,RH,Y/O,W/B,Y1 What wires do I hook up to...
Hook up like this:
R-RC (jumper rc with rh) unless you have more than one transformer
Y-Y/O
G-G
O-Y/O (depending if reversing is energized by O or B terminal, refer to your manual)
W2-WB
Dec 06, 2008 | Heating & Cooling
If you don't have the wiring information, go here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf and see page 10.
If you're still having problems, go down to the furnace room and find the piece of equipment that you're wiring to.  See where the wires came from, transpose that to the information above.  Note: the wiring from the relay box should be 24 volts which is safe to handle.  Wiring inside the relay box may be 110 or more volts which is not!!!  Cut power before opening relay boxes.
As far as heater running continuously, be sure of your wiring.  You may have the gas relay lead and the fan lead reversed.  Determine if you've set the switch options for your type of heater correctly!!!  Do you hear the relay clicking in and out at or near the room temp when you change the setpoint?  If not, the unit may be defective.
Nov 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44360 problem
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
528 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
