Brother DCP 7010 Multifunction Laser Copier Logo
Posted on Mar 11, 2010
When ever i try and scan a document, i get a message that sais that "the system cannot find the specified file". due to this problem i can scan anything.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
81
Points
Hello Jazzist91
I have the same problem with a new laptop running windows 7. Seems like something is wrong with the win 7 driver as the 7010 scans fine with my old laptop running vista. I tried activiating the microsoft scanner and using this but this also doesn't work which is why I think it must be the scanner driver.
I also tried re-installing the brother software abd faithfully followed all instructions. No joy either.
So I don't have a solution to our problem but I guess brother will eventually fix it.
Did you get anywhere with it? If so let me know
1helpful
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Wla lng
! C:\Documents and Settings\pc 1\My Documents\Downloads\FCFMODZ4.5.zip: Cannot open sxs.dll The system cannot find the file specified. ! C:\Documents and Settings\pc 1\My Documents\Downloads\FCFMODZ4.5.zip: Cannot open sxs.dll The system cannot find the file specified. ! C:\Documents and Settings\pc 1\My Documents\Downloads\FCFMODZ4.5.zip: Cannot open sxs.dll The system cannot find the file specified.
How can i use my pixma mp210 printer to tranfer a picture into my pic file on the computer
Hello my friend,you mean to scan a photo and save it on your folder?
If yes
  1. You run the application MP Navigator from your dekstop (or from Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.)
  2. When the one-click mode screen has opened, click the Switch Mode button to switch to the navigation mode screen
  3. Point to Scan/Import and click Photos/Documents (Platen).
  4. Place the document face-down on the platen, and select Document Type.
  5. Click Specify... and set the preferences as required.
  6. Click Scan and it should start scanning
    When scanning is completed, the Scan Complete dialog box opens. Select Scan or Exit. Select Scan to scan the next document, or select Exit to end.
    When scanning is completed, the scanned image appears in the Thumbnail List area.
  7. Edit the scanned image as required.
  8. Click Save or Save as PDF file.If you choose just Save and box will appear to specify the destination folder, file name and file type(usually images are .jpeg .jpg ;) ).
  9. And click Save and your done.
Scanning Photos and Documents
1helpful
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Computers crashed due to an outage...cannot scan docs
Reboot the machine first. If that doesn't work, go to user tools - system settings - file transfer or interface settings (depending on the model) and enter and admin email address. Then go to admin tools and tell it to auto specify a sender. It is looking for who is sending the scan, not who is receiving it...
2answers
The scanning feature doesn't work
Make sure once you have the software installed properly that you set up the file ( address) correctly. You need to have the designation specified.
26helpful
6answers
'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Drivers won't download
Use this link to download: http://www.download.com/3120-20_4.html?tg=dl-20&qt=abby&tag=srch
Norman Weimar
Norman Weimar
k24674
