Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GW711
I bought this washing machine from a second hand shop yesterday. I found out today after doing the 3rd load since I bought it the machine came was in the spin cycle the lights that illuminated were the 4th from the left as well as the spin light. It beeped every minute. now the machine will fill wash won't spin the rinse and won't spin dry at the end. Suppose this is what I get for trying to pick up a good machine from a seconds place.
Please help I have 5 kids of school age it will kill me to hand wash all their clothes.
Pump stuffed. New one on ebay for 50 bucks. 10 min job if youve done one b4, 30 mins if not. Get underneath, no tools needed - unplug first, drain as best u can. Unplug lead from little pump motor, pull plastic side clip back and rotate motor to remove. Fitting is reverse. Easy
Posted on Mar 31, 2012
    Sergeant:
  • 351 Answers
Is it making a humming sound at the spin,is it draining you may have a blockage try turning the black fan on the pump front right underneath.hope this helps.
Posted on Mar 09, 2008
My old Fisher and Paykel GW711 washing machine worked fine until I moved house. It worked fine a few times here, too. But now it fills, but then doesn't start the wash cycle, then after about an hour, it...
sounds like an electronic problem. motor controller most likely. I am unsure off hand what this fault (7) means, but the number is very low, which normally indicates motor control board
Sep 12, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
G'day, we've just bought a fisher and paykel wl80
Every one I've worked on a few lately and both of them have had thermistor leaks in to the control board area causing the control board to fail, Sounds like you may have the same problem.. Remove the top control area and check for water. Good luck
May 13, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10 US won't spin
Buy an new one and trash this one
Sep 13, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
514 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
