I am having trouble downloading Adobe Photoshop elements 6.0 it starts to download and then the server drops out I restart the server it starts downloading again but it only runs for about five minutes.
  • 40 Answers
I am presuming you are downloading it from Adobes' website
it works via a FTP so it is possible internet settings are keeping you from downloading it,
might I suggest a alternate download location of the file such as
http://www.download.com/Adobe-Photoshop-Elements/3000-2192_4-10057110.html
Posted on Mar 08, 2008
Hello: I have Adobe Photoshop Elements 6.0,Windows XP with Pentium 2.8Gz and 1.59RAM. I set off on a mission to organize family pics but Photoshop Elements is driving me crazy due to several...
whats Graffi\'s automatic program, it sound like this program is incompatible with adobe photoshop elements. what format wereyour original files before you opened them in phtotoshop elements?
Feb 02, 2011 | Adobe Photoshop Elements 6: Windows
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
Lost my product key for adobe photoshop elements 6, is there any way I can retrieve it, or can someone give me it
Hi Dorrie,
I'm sorry but Product Keys and their replacement is done solely through the product manufacturer.
If you registered with Adobe or only have the receipt, there should be no problem getting a replacement through them
Click here for the Adobe FAQ page pertaining to Photoshop registration and Prod keys
Best regards
Mike
Sep 24, 2009 | Computers & Internet
Adobe photoshop elements (editor) has stopped working
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:Program Files (x86)AdobePhotoshop Elements 7.0Localesen_USPlug-InsImport-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jun 10, 2009 | Adobe Photoshop 6.0 for PC
I have the following message and I understand the problem may be with Adobe Photoshop Elements 6 The appplication has failed to start because connAPI.DLL was not found. Re-install may fix the problem
Hi there.
Do one of the following solutions: Solution 1: Remove the NOKIAManager.mox file.
  1. Exit Photoshop Elements.
  2. Open the C:\Program Files\Adobe\Photoshop Elements 6.0\moxplugins folder.
  3. Move the NOKIAManager.mox file to the Recycle Bin, or another location such as your desktop.
  4. Restart your computer.
Note: The NOKIAManager.mox plug-in file is required for Adobe Photo Downloader to download photos from a Nokia mobile phone. If you use a Nokia mobile phone, use Solution 2. If you later decide to use a Nokia mobile phone, either move the NOKIAManager.mox file back to the original location or reinstall Photoshop Elements.
Solution 2: Install or reinstall the Nokia PC Suite software.
Note: Only use this solution if you connect a Nokia mobile phone to your computer.
In order to communicate with a Nokia mobile phone, your computer must have the Nokia PC Suite software installed. Install the software to allow Adobe Photo Downloader to communicate with the phone and download photos from it. If you have previously installed Nokia PC Suite but are still getting this error message, uninstall and reinstall the software or upgrade to a newer version. For more information about Nokia PC Suite, contact Nokia or visit the Nokia web site.
Solution 3: Disable Adobe Photo Downloader.
  1. Open the Organizer in Photoshop Elements.
  2. Choose Edit > Preferences > Camera or Card Reader.
  3. Disable the Auto Launch Adobe Photo Downloader On Device Connect option.
  4. Click OK.
Note: This solution will prevent Adobe Photo Downloader from starting when Windows starts, and it will not appear automatically when you plug in a camera, card reader, flash memory drive, or other memory device. When you plug in one of these devices, and in order to download photos into the Organizer, you will need to start Photoshop Elements and choose File > Get Photos or Videos > From Camera or Card Reader.
Good luck and thanks for using FixYa!!
May 01, 2009 | Adobe Photoshop Elements 6: Windows
How can i download adobe photoshop free
i cont't download adobe photoshop(free). pls help me.
greatmaba@yahoo.co.in
Feb 05, 2009 | Adobe Photoshop 7.0 for PC
Photoshop Elements 5.0
Adobe Photoshop Elements 5.0 User Guide is available: CLICK HERE. After you click the link, scroll down and click the 'Free' button. After waiting about a minute, you'll be able to download the PDF.
Free tutorials are available, and they are many. The best 'free' ones are on About.com: FREE ELEMENTS 5.0 TUTORIAL
Adobe Total Training offers better training, but you have to pay for it: CLICK HERE TO PURCHASE ADOBE TOTAL TRAINING DVD.
Alternatively, here is an article that might be of some use:
http://graphicssoft.about.com/od/pselements/qt/freegoodies.htm
I hope this will FixYa!!!
Feb 12, 2008 | Adobe Photoshop Elements 2.0 for PC
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
