Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Screen Doesn't turn on, light blinks four times
I have a Trinitron WEGA model # KV-27FS120, chassis style B06. At least, I think its a B06, the numbers have mostly flaked off. It was manufactured in Nov. 2005. When I plug it in and press the power button, it clicks, blinks four times, pauses, then blinks four times again. It continues this pattern until I unplug it. If someone could just point me to the right fuses, or whatever it is that is screwing up, I would really appreciate it. Also, I don't know too much other than how to solder and what a resistor looks like.
Thanks
Erik
  • Albuquerque Mar 16, 2008
    The tv will not turn on but a red light flashes nine times where the on/standby button is.
  • 129 Answers
Good day.
First, A resistor looks like a little tube with different colors placed in stripe form and has two ends or terminals. The colors represent the value the 1st and 2nd 3rd being the significant digits. The 3rd is the multiplier and the 4th is the tolerance.
Consider the vertical IC of your unit being the cause of this. Also, there are cases wherein the X-ray protector resistor is to be blamed.
chris
Posted on Mar 11, 2008
Light blinking 4 times and no picture
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
If you wish to get more details, check the site linked here.
Nov 27, 2013 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can't see anything
adjust the screen at the CRT section
Sep 27, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27S42 four time blinks
pls let me know, are you TV tech? or just trying at your own.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27FS120 blinks 2 times continuously...
This is not for a DIY're.
It is possible that the flyback transformer and the horizontal output transistor have failed. Also there may be damage in the power supply when these components fail.
When troubleshooting, it is important that the tech locate the cause of the fault and also change the related components.
After the parts are changed, the power supply and the high voltage setups must be done to make sure that the voltages are in specs.
This type of work must be done by an experienced TV tech. He will have the necessary test equipment, tools, service manuals, and training. There are some very serious safety issues when working in a TV set.
Jerry G.
Jun 19, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Light blinks four times, screen doesn't turn on
PER TO WHAT SONY HAS TO SAY IT IS A VERTICAL PROBLEM. SOME TIMES TH EIC JUST NEEDS TO BE SOLDERED. IT IS ON A SMALL HEAT SINK IC545. IF IT IS NOT SOLDERED GOOD THE YOU PROBABLY NEED TO REPLACE IT.
There are three defects can cause the Standby/Timer LED to flash in groups of four:
1) +13V and/or –13V from FBT/pins 9 and 7 respectively are missing on Vertical Drive IC545.
2) Vertical Drive IC545 is defective (no reference pulses output on IC545/pin 3 to IC001/pin 78).DON...
Mar 09, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
