Question about Onkyo TX-SR601 Receiver
Onkyo Zone 2 Problem
While trying to increase the volume of zone 2, I get a message "Powered Zone 2 is not Activated"
Where to look next would be appreciated
Regards
Grant
  • sr701 Mar 08, 2008
    G'day Graeme
    Thank you for your assistance. I had a copy of the manual and your advice to check out page 55 hit the mark. All sorted now but not sure how the config changed. At least now I will know how to fix if happens again.
    Thanks again
    Regards
    Grant
  • 1,512 Answers
Hi there
The only reference i could find to this in the manual is on page 55, in your hardware settings. It relates to the menu settings for remote control configuration/zone 2 activation. Do you have a user manual to help you here? Hit the link above and enter an email address and you can down load one. Good Luck, any dramas,feel free to comment back to me here and we can sort it out)
regards
Graeme
Posted on Mar 08, 2008
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
Zone 2 stopped working. When pressing the volume button for Zone 2 , message appears : "Pwrd Z2 not Act." Do you know how to correct?
Go into Hardware Setup, find the setting for Powered Zone 2 and ACTIVATE IT. You will lose the Surround Back speaker function when you do this. Zone 2 and Surr Back are mutually exclusive.
Jul 14, 2010 | Onkyo TX-SR703 Receiver
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
Powered zone 2 is not activated onkyo txsr602
You have to make sure that you have activated zone2 in setup? It is defaulted as 7.1 Activating zone2 makes it 5.1 + 2 (make sense)
Also zone2 only outputs audio hooked up thru the analog connections
Apr 09, 2010 | Onkyo TX-SR602 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Onkyo 805 zone 2 problem
I just figured out what I was doing wrong last night. On the 806 at least, when zone 2 is not powered (receiver is set to act) there is a separate volume control 'level' that is on the receiver a couple buttons right of the zone 2 button. By default this level appeared to be set to -50db. As soon as I turned up this level sound came out of my zone two.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
Onkyo TX-SR601 Receiver Logo
1,100 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
