Question about Dishwashers
Maytag Dishwash - No lights will light up on the control panel
My dishwasher will not turn. None of the lights on the control panel are on. How do I test the control panel or other things to determine the problem.
  • 3 more comments
  • mmickler Mar 08, 2008
    I have check the breaker, it is fine. I have checked the door switch, it is fine. I have replaced the control board (thinking that was the problem) so now I'm working with a new one and still hav e the same problem. Before ordering another $100 part (control panel) I want to check it to make sure that is the problem but I don't know how. Thanks
  • Anonymous Dec 11, 2008
    Hello. Have the exact issue. The panel was replaced about 12 mo ago. There is power to the machine but the panel is dead
  • Anonymous Feb 06, 2009
    I have a kenmore 17369 dishwasher built-in. I'm getting no lights coming on the control panel and the dishwasher won't do anything. I have checked the main breaker and it's fine where the power cord plugs into it. Do you have any other tips on what to do?
  • 97mama Mar 12, 2009
    I have the same problem kenmore 665.15934 ckd breaker,wire connection, 110 v is ok so it is not electrical and door seems to latch properly
  • Anonymous Mar 28, 2014
    getting power to dishwasher,but no lights on control panel
    President:
  • 2,651 Answers
First off ck the breakers ofr tripped breaker, next remove lower acess panel and on right side is main wire connection remove box cover and make sure connection is good. ck fro 110 v there if not you got an electrical issue. next would be to check the door switch assy's.
Posted on Mar 08, 2008
All of the lights are on and none of th control buttons work
The drainage tube may be blocked. I had to remove the end connected to the garbage disposal and flushed it out. The lights immediately went back to normal.
Nov 28, 2011 | Maytag Dishwashers
No front panel lights Whirlpool GU2500XTPB1. Power to dishwash is good.
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it (ZERO OHMS) using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Aug 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Dishwasher works only in Rinse and no lights on the Control Panel
I HAVE SEEN THIS BEFORE ON SEVERAL DIFFERENT MAYTAG MODELS AND EACH TIME, IT HAS BEEN THE ACTUAL TOUCH PANEL WHERE YOU MAKE YOU SELECTIONS. I HAVE PROBABLY SEEN A DOZEN OF THESE IN THE LAST COUPLE OF YEARS. HOPE THAT HELPS.
Jan 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
Clean light flashes 7 times
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
NOTE: There should be a tech sheet located behind the lower panel under the door that lists all the fault codes and how to troubleshoot them. If you need further assistance, please let me know.
Jun 20, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwashers Logo
508 people viewed this question
Top Dishwashers Experts
