Acer LCD TV screen burn.
I left my TV switched for 2 hours MAX with the HD box switched OFF.
When I returned home the screen was showing a blue colour,and in the centre of the screen the words "No Signal" was displayed.
Switching ON the HD box to watch TV, in the centre of the screen the words "No Signal" can be faintly seen in a Red colour.
Could you please help me and advise me how I can rectify this problem.
Regards Ross.G (Australia)
Acer LCD TV Model AT3201W WxHxD 1018x616x210
Resolutions 1366x768
  • 492 Answers
Burn in unfortunatly is permanant. It damages the liquid crystals that produce the image.
Posted on Mar 08, 2008
I've had U-Verse for a few years, which my TV is hooked to. All of a sudden the TV shows are not taking up the entire screen. I have used the "access", "menu" and every other button...
The box had something on and is not suppose too.Can't remote or manual turn off.Try unplug,replug the U-Verse box back about an hour later.By letting the U-verse box rebooting and upgrading it softwares,should solved the HD LED lighting up problems.
Mar 01, 2011 | Olevia 237T 37 in. LCD TV
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
How to get rid of the blue screen on av channel
you can't. it is built into the microprocessor to drive the blue.
want a cool tv? switch the rgb drives around. then you could have a green or red screen and green people.
Sep 10, 2009 | Acer AT3205-DTV 32 in. HD-Ready LCD TV
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Jun 22, 2009 | Polaroid FLM-4201 42 in. LCD Television
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Sony KDF-42WE655 (LCD 42 inch)
I have the exact same problem with my 42" LCD HDTV. When I called Sony "customer support" they told me NOTHING. However, I began researching this issue and found out that Sony knows all about this problem. It's a part called the "Optical Block" and THEY are supposed to reimburse you for the repair! The claim form is on the Sony Website. Here's the link: http://esupport.sony.com/US/perl/model-home.pl?mdl=KF42WE610&LOC=3 Look inside the yellow box on the right and click on: Additional service coverage information for your TV (scribble / line pattern on screen) Hope this helps you!!
Apr 28, 2007 | Sony Grand WEGA KF42WE610 42" Rear...
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Televison & Video Logo
554 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
