Question about Motorola Mobility RAZR V3c Cellular Phone
Outside screen is blue
Today I looked at my outside screen to see who was call in when my phone rang. The screen was blue with no time or name for caller ID. I shut it off and pulled the Batt. out. I let it set for 1 or 2 minutes. and put the Batt. back in. I turned it back on and still got just a blue screen. The inside screen works just fine. Any Ideas.
  • cswooten123 Mar 11, 2008
    i opened my screen and the outside will work just fine but the outside would just stay blue i tried turning it off taking the battery out and even resetting it but i did not work any one got answers
    Brigadier General:
  • 7,752 Answers
Have the lcd replaced on both phones.
Posted on Jun 29, 2008
The phone's picture shows lines and discoloration
May need to take it to cell phone repair mine looks the same way. Dropped it face down. Did your screen crack at all. Shouldn't be too much to repair it they quoted me $100.00. Hope this helps.
Mar 14, 2014 | ZTE Score
Dropped my phone an the screen is turnng blue
The screen is broken as a result of the drop and needs a replacement.
Apr 23, 2017 | Motorola RAZR Cell Phones
Purchased scratch and dent kenmore electric range model 96419. Did not see when I looked at store that the handle was broken, also the door does not want to stay shut. I close it and the door pushes...
not all scratch and dents are plug and play yours sounds like it was dropped or received a damaging blow you will need to look for door replacement parts and possible alignment of door or body frame
May 30, 2017 | Kenmore 96412 / 96414 / 96419 Electric...
RANGE ROVER 2004 L322 DRIVER DOOR WONT OPEN FROM OUTSIDE BUT OPEN FROM INSIDE.
Hi, take the inner door panel off, look around should be a rod that goes from the outside handle to the door latch mechanism, its either broken or unhooked.
This is how i solved a similar problem. When I removed the door panel and looked inside I was able to see the small rod that attaches to the outside handle was not connected. I tried to snap it back in but it wouldn't stay so I pulled the rod over where I could see that the small plastic part on the end of the rod that holds it in place had one side snapped off. Should be easy to fix once I locate the part. Just did this today and haven't looked for the part yet.
Dec 09, 2010 | 1998 Land Rover Range Rover
All of a sudden today my phone rang, I answered it, then the screen went blank...at times it shows a split gray/dark gray screen.
Switch off and on your phone, if screen is in same mode , then there will be problem with your display....Take to service centre.... and service it...it will work...
Let me know feedback..
Thank you...
Oct 02, 2009 | Sanyo Katana Eclipse X Cell Phone
Outside screen
You need to take back up of your phone and master reset your phone. The problem will be solved.
Oct 22, 2007 | Motorola Mobility RAZR V3
White screen
hi
try opening your phone and check if its flex connector is still in contact.  if everything is fine then probably you have a problem in the flex itself...
if eveything is fine then worst you have a defective LCD..
Oct 12, 2007 | Motorola Mobility RAZR V3
Blue screen on outside display screen
you need to have the LCD replaced on the mobile.
Jun 28, 2007 | Motorola Mobility RAZR V3
Black Outside Screen
When you are looking at the RAZR, push the button on the right hand side. This should light up your outside screen to see the time when the screen is dark. Have you tried this?
Dec 23, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
