Question about Kenmore 55693 Side by Side Refrigerator
Ice maker won't stop making ice
I have a side by side fridge and the ice maker shut off is an infared switch instead of the common lever arm. For some reason my ice maker is making ice non-stop even if I manually flip the on/off switch plate that blocks the infared signal. Any help on what could be the problem?
    President:
  • Kenmore Master
  • 2,651 Answers
Souonds like that sensor has gone bad, doenst know its full and contionues to make ice. youll need to repalce the electronic board.(they come as a kit both emitter and reciever,)
Posted on Mar 08, 2008
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Apr 05, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My BI98 u-line ice machine won't stop making ice even with bin arm up.
I would suspect the switch controlled by the tray full sensing arm/bail. That's kind of like the main power switch for the ice maker. You can remove the outer cover from the ice maker with the power unplugged! Then look at the mechanical operation of that lever as it relates to the switch. The lever should cause the switch to open and shut off the timer motor. Some times you can buy the timer separately otherwise you replace the whole icemaker. Don't forget to remove power and turn off the water before you remove the old icemaker.
Oct 15, 2014 | U-Line BI-98
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My LRSC26923TT side by side fridge/freezer has stopped making ice. It still dispenses water but it would not dump the last tray produced. I removed the cubes from the tray by hand, emptied the freezer, and...
Unfortunately, Ice Makers are notoriously unreliable and most require more expertise than a handyman possesses. Most require replacement of one of the 4 main parts (usually not generic): drive motor, water solenoid, heating release element or bin full ice arm control switch.
A Certified Technician should be able to diagnose the problem and suggest a repair or replacement.
Apr 22, 2017 | LG Refrigerators
Ice maker not working went on vacation and turned water off. seems the watr guide into the Ice maker is blocked. Was wondering why this happens, as action should be similar to stopping Ice making with...
When the water is shut off by the lever, it is shut off at bottom of fridge. When you shut it off, it is allthe way to the tray as it gave water permission to travel and what was left filled the line. Unplug fridge for an hour. Should be fine
Aug 09, 2009 | Whirlpool ED5FTGX Side by Side...
Fridge and Freezer quit working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice maker
couldnt bring up your model #... should be a off / on switch or arm to raise, should be able to shut off your ice maker... cant imagine what could be making a sould like a motor cycle lol
Aug 28, 2007 | Frigidaire FRS23R4A Side by Side...
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Kenmore 55693 Side by Side Refrigerator Logo
302 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
