17" Samsung 715v won't display anymore, it will just give a moving message that says "1280 x 1024 VIDEO RESOLUTION..." but will stay the same no matter how much i tried adjusting the computer's resolution. Is the monitor damage already?
  • Anonymous May 18, 2009
    Same problem with my Samsung 715v...
  • 34 Answers
What do you mean adjusting computers resolution.
Posted on Mar 08, 2008
My monitor samsung 740n is displaying a message "not optimum mode"
You must set it's performace from display properties( appearance and settings), so video card should work fine.
Mar 30, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
How do I change the display resolution on the control panel ABOVE the maxed out resolution shown so I can use a 17' screen which requires 1280x10xx? When I try to use any 17" monitor, a message comes...
On a 17ins monitor the best resolution is 1024x768 regardless of whether it tells you a different "recommended" display resolution.
Just ignore any warning it gives you and it should work very well with the resolution i've told you, just use the slider to select the 1024x768.
Regards.
Dec 09, 2010 | Acer Aspire AX3300U1322 Athlon II X4...
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a samtron 74v and upon booting up the screen stays black and a message flashing across my screen says "no optimum mode, recomended 1280 x 1024 : 60hz" but how can i change the resolution and...
Running XP? Boot the PC in safe mode (hit F8 key while PC is booting up and select safe mode), then set the video resoltuion to 640 x 480, reboot into regular boot up, reset the video resolution to 1280 x 1024 @ 60Hz.
Mar 19, 2010 | Samtron 74V 17" LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
It saysmy pc video resolution is out of range
to chabge resolution go to click start
control panel
apperance and themes
display
settings
and down towards lower left hand you'll see screen resolution
then move bar to 1024*768
Mark
Apr 11, 2009 | Samsung 710V 17" LCD Monitor
I have a 715V with the same problem
This is a problem with the interface or digital signal processing board.You need to replace this board which plugs into the Signal input.
Samir
Feb 15, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
