Question about HP Officejet Pro L7680 All-In-One Printer
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the printer and Quickbooks and then reinstalled. It still didn't work.
  • msrealty May 26, 2008
    HP L7680 All in One.
    I have spoken to an HP Advisor for 7 1/2 hrs to get the All In One To work. No success. I hired a tech, he got everyting to work with one exceptions the scanner. Scanner will Not scan To Memory Device. Message: Memory Device was Not Found. If I can get letters to print out from my computer to the L7680, I should beable to get the scan to be received by my computer. No such luck as yet. Do you have a solution? Please Post!
    Guru:
  • 79 Answers
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Posted on May 25, 2008
Why is Hp 2840 color laset printing many pages than requested
This is usually a driver issue. Most times you can download newest driver from manufacturer website. If this does not fix the issue you might have to find an older driver that works. Make sure you completely remove old driver and all software associated. Remove printer to pc connection and only reconect as driver or software ask you to do so.
Jun 11, 2014 | HP Color LaserJet 2840 All-in-One...
Hard reset on HP l7680
you have to reinstall the driver again ,full software, hope was helping you .
Mohamed Hejazi
Mar 26, 2013 | HP Officejet Pro L7680 All-In-One Printer
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
Need to download software for HP L7680 to HP
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=2512009
download the device-driver for your Operating System.
Apr 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Cannot install Scanner for HP M1522nf on Windows7 platform
Windows 7 is very new, and there are not a ton of drivers out there for it. Start by going to HP's website and click on the support and download tab. From there, enter the model number and select the version of win 7 you have. Download the drivers, and see what happens.
Here is a link, but I am not sure it will work:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3442754&taskId=135&prodTypeId=18972&prodSeriesId=3442750&lang=en&cc=us
If they dont work, try the newest Vista drivers. If all else fails email HP. However, the Win 7 drivers should work just fine. (I have a similar unit and the drivers worked like a charm.
Hope this helps\
Jer
Jan 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP L7680 All-in-One will not scan or fax
connect the phone line in printer and set the parameter like auto answer and sending and receving mode also install the scanner driver .just reinstall the printer driver it will installl the missing components.
Dec 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scan doesn't work
i have a hp F4272 all in one ,when i used the scanner hp cue scanning flow component has stop working,any one who has an idea of this problem?
Sep 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 Scanner & Software function - cD does not load fully
This is an educated guess but your problem is most likely a driver/software file conflict which is causing the software to bork before it completes the installation.
In all honesty the HP software is bloatware that is frequently identified as more trouble than it's worth. So, my recommendation would be to try and locate a more suitable software package that will work with the scanner to do what you want instead.
You are probably best to download the basic driver only package for your unit and then completely remove the old software before installing fresh (remember to unplug the printer before you install the new drivers).
I appreciate that this is not the most elegant solution but as I noted the HP software is not overly user friendly and in the interests of retaining your hair, sanity and keeping therapy bills to a minimum I'd invest your time in finding a more suitable application that will work with a TWAIN scanner (which the HP L7680 should be).
Hope that helps and good luck...
Martin
May 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
HELP !! L7680 Installation causes resources to go to 1000%
End the files from the Taskmanager to work with the printer. Try to search for the HP Digital Imaging Monitor from C:\Program Files\HP\Digital Imaging.
Double-click on the hpqtra08 file to run the HP Digital Imaging Monitor.
Dec 09, 2007 | HP Officejet Pro L7680 All-In-One Printer
Scanner won't work
hi,dahaka,
I did, but can't find the "Hp director" .
(start, all programs, HP) in "Hp" don't have Hp director!) where can find it?
bhca
Nov 29, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
242 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
