Hard disk replacement for lacie ethernet disk mini 250 gb
I would like to replace the hard drive of my lacie ethernet disk mini.
can i put a bigger hard drive or it has to be of the same size.
How should I replace & what is the procedure.
  • 1 more comment
  • Anonymous Nov 15, 2008
    I'd like to swap the exisitng 250GB drive with a 500GB one. How do I do it?
  • trapizoid81 Jan 16, 2009
    My drive just died. Need to place it
  • Anonymous Mar 03, 2009
    I just want to increase the drive size, but when checking around I came across posts about this drive.
    The OS is Linux, and the partitions and system is on the hard drive itself.
    To change drives you will need to setup the OS on the new hard drive first and swap it into the EDmini case.
I managed to fix mine with a little bit of work.
This website has a readme file that specifies the partitions. You must be using Linux.
http://gpl.nas-central.org/LACIE/ethernet_disk_mini_v2_-_ethernet_big_disk/EDmini_v2_partition_images/Readme
1. Plug the drive in a Linux computer, or use a Linux Live disk.
2. Create all the partitions according to the readme file. Use extended partition for the first "container". Linux Swap for the second partition. Use Ext3 format for the remaining.
3. Extract all the SDA6-8 files with bzip.
4. Use "dd" command to write those images to partitions sda6 - sda8 which you just created with this command: dd if=/dev/home/ubuntu/sda6 of=/dev/sda6 bs=512
5. Substitude /home/ubuntu above for the location where you placed the image files.
6. Once all 3 images have been written, the drive should be good to go. Put it back in the edmini, start it up and see if the website comes up. You may have the "format" the drive from the admin utility once its up and going.
Hope this helps.
use the "dd" command in
Posted on Mar 17, 2010
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
When turned on LAcie hard disk is noisy, then asks formatting
Please try it on another computer. It seems to be a hardware issue with the drive in case you are hearing a noise coming from it. In case it is under warranty, please get it replaced ASAP.
Apr 29, 2010 | LaCie (300770) 250 GB Hard Drive
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
Nov 08, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
My Lacie just quit working
Please reinstal the your operating system with drivers
Jul 05, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie will not mount
hmm..power it down...wait a minute or three..try again..
may need new set of drivers..
Mar 28, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Computers & Internet Logo
9,494 people viewed this question
David Payne
David Payne
