Question about Magic Chef CGR1110 Gas Kitchen Range
Oven Sometimes when I start the oven it will light, run for a while & go out. Sometimes it will stay on up to selected temp & then go out. Especially frustrating when I'm baking something that needs to be baked for an hour or more. The other night I set the oven for 350..let it pre-heat while I made batter for 4 dozen cupcakes. I put the first dozen into the oven & 17 minutes later.I had warm cupcake batter. Sometimes it works just fine! & weather doesn't seem to affect the function of the oven. Our propane tanks are full. What the heck is going on? The stove is only 2 years old!
    President:
  • Magic Chef Master
  • 2,651 Answers
Sounds like a bad ignitor, sometimes lighting and not relighting during extended cooking time. dies it take longer than a minute to ignite gas? more then 10 in to preheat? smell gas while cookin?? all signs of a bad bake ignitor
Posted on Mar 08, 2008
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Oven temp doesn't stay constant
your clock/timer control board controls the oven. the switches control the top. if connects were a problem until you moved them to a certain position then replace ends. but your problem with the temp. is gonna be fixed by replacing your control board.
Jun 19, 2009 | Kenmore Ovens
Kenmore gas oven temp not accurate. Could be high, can be low.
the oven themperature needs to be calibrated, the set screw it's in side of the oven knob when you remove it in the senter of the shaft there is a very small screw, turn it , beon that replace the thermostat.
Dec 06, 2008 | Kitchen Ranges
Maytag oven won't stay at temp.
new ignitor is you problem part number 1240035, wont reignite after reaching temp, common issue with all gas stoves
Nov 10, 2008 | Kitchen Ranges
Intermitant falure frigidaire gallery oven
Are your door hinges bent thus keeping the door open slightly? this way the thermostat might click off.
Oct 16, 2007 | Thermador SC302T Electric Double Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Magic Chef CGR1110 Gas Kitchen Range Logo
385 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
