Sys Mechanic-7 Poor operation
Sys Mech-7 Pro:active care popup "loading data" stalls @ 12% for hours.
    Problem Solver:
  • 18 Answers
System mechanic 7 is a heavy application. it uses lot of system resources ...ensure u have atleast 512 mb of RAM in your system and you do not use any other program while using system mechanic
Posted on Mar 08, 2008
3cyl, or 4cyl, never ask for engine help not stating the engine options.
A/T tranny Right not STICK shift manual..
stuck in 3rd but trans is ok. (a gross contradiction if ever)
why not listen to him, if it stuck in any gear , there will be huge power loss. why not scan it."? is your mech, a non ASE? tech?
(if you mech, can say which end is bad, find a new mech)
get the errors. from the engine and the trans.
here is the easy way to see which is wrong.
1: do the FSM stated transmission stall test. this takes me 1min.
a: hand brake set hard.
b: car pointed is safe direction (mother inlaw?, LOL)
c: chock front wheels to ground. (aka; blocking wheels)
d: warm engine and cold (i try both , due to trans, fail both)
e: foot on service brake pedal. hard, say 50lbs force.
f: WOT the engine, wide open throttle (per FSM)
g: read the tachmeter, (on dash or tool) or scanner.
all USA cars 97 you can read RPM with any scan tool ever made.
h: see RPM rise and stop, this is STALL speed.
what your doing here is making poor mans DYNO.
if the tranny slips, the RPM goes out of control. tranny bad.
if the tranny dont slip RPM look like this. it loads up and goes
to near 2000 rpm. and holds, (full engine power)
if the engine is weak, the RPM will be less. (read the FSM)
google "automatic transmission stall test"
or read the FSM in the the on car test for A/T? there are many.
once you know which end is bad, we can diagnose that too.
have you done the 60k miles service yet? if not , why not do that now.
spark parts, filters, yada,yada. ,need list , its in the operators guide
and in the FSM. both.
Mar 29, 2014 | 1997 Geo Metro
2000 Camaro fuel pump/ fuel filter/ and fuel pressure regulator all replaced, still no gas getting to the motor.. mechanic is stumped, don't know what it is.. my car started getting harder than normal to...
i can tell your mech is not ASE pro. not at all.
guessing is for squids.
a pro uses his tools.
he didnt now you are broke, find a real ASE mech, and save $$$
so what was the fuel pressure.
if the pressure (generic answer) at the rails is not 30 psi
and your mech cant figure that out, fire him.
dont argue with him, just move on.
if the pressure is good at the rail and 1PSI (squirt tests are useless) then check the pumps stall shunt pressure.
if at spec the regulator is leaking.
if the pump fails the shunt test its is weak.
check for 12v key on for 3 seconds in to said pump.
if 12v dont land there, bingo now power.
sorry 8v is no good, 12 or as low as 11v lowest there, at the pump.
the pump is not running full time the ECU prevent that and the
TV crash and burn issue. it runs for 3 seconds each keyon.
some older cars, only have pump voltage cranking.
read the FSM , its all there, including all the test and all these pressures, .
sorry your mech, sux, truely ! i am sorry for you.
find the ASE badge on his /her sleeve, see that>\?
no? the Walkonbye. (pun included )
Aug 17, 2013 | 1986 Suzuki Samurai
Cannot run a virus scan, sys mech 10 pro
Upgrade to ver 10.5 and the problems are solved.
otherwise, I had to un-install it completely.... then re-installed it. It asked me to go on the internet for updates and it automatically gave me v 10.5 which fixed the scan HD issues.
Otherwise, boot the computer and press F8 and type this at the DOS command prompt.
chkdsk /f
This will fix the HD issues. Reboot and try System Mechanic. It should work from this point.
No other options available. Either of the 2 solutions given will work for sure.
Any doubts you can get the help of a certified technician through the website:
Aug 07, 2011 | Iolo Technologies System Mechanic: Windows
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
How do i get free unlock code for g1 google phone
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
Program won't start. Get message "the component IoloSystemService" is required for system mechanic to operate properly and could not be found. System Mech 9.5.6 is installed and looks good. Running XP,...
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Click Yes to confirm.
Reinstall the System Mechanic Pro
Mar 06, 2010 | Iolo Technologies System Mechanic: Windows
Running Windows 7. A windows Critical Update auto installed on Thursday and system ran fine for several hours. Then it hung and I had to re-boot. It would not reboot, not even into Safe Mode. It would...
it more than likely has little to do with the operating system. It sounds like a hard drive problem. Are you able to format the harddrive and reinstall?
Jan 30, 2010 | Computers & Internet
How to create program in delphi
i wants to create form for data input
with the condition
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
