Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub Zero Freezer Vacuum
The whooshing vacuum sound no longer happens when I close the freezer drawer. Is this costly to fix. If so can I let it go, it's a 15 year old Sub Zero.
Thanks
  • Anonymous Mar 15, 2014
    sub zero problem with track freezer
  • 26 Answers
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Posted on Mar 31, 2008
Vacuum light on?
In 90% of the times, from my 5 years experience with subzero repairs, it will be leaking evaporator coil, compressor will run longer then suppose to (it still might keep temp). But first You need to check on all fan motors if they run. Also visually check if there is any snow or ice builds up in freezer and refrigerator compartments. if everything looks normal, then You need a serious repair. Here is video I made how to replace evaporator coils. Hope that was helpful!
Mar 07, 2015 | Sub-Zero 650 / O Bottom Freezer...
Freezer not functioning properly
I believe you need the Sub-Zero Service Manual to answer your questions. Your model is listed in the manual which explains how to cause the forced defrost electronically. I believe it is done through the keyboard as defrost on your refrigerator in electronic and not done with a typical defrost timer that you will turn. I may be able to answer a few of your questions, Thanks John Tripp Appliance 911
Feb 20, 2014 | Sub-Zero Refrigerators
My sub zero refrigerator makes a gurgling sound when you close the refrigerator door - sound is coming from the side of the unit.
Hi this is the drain tube sucking water back up through, this is caused by the vacuum inside the refrigerator that is formed when the air condenses, not much you can do about this sound its fairly normal.
Sean
Apr 01, 2011 | Sub-Zero 650 / O Bottom Freezer...
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero freezer door no longer vacuum seals when the door closes. There is nothing obstructing the door.
Make certain that the freezer fan motor is operable. Otherwise, contact an appliance service company.
Feb 20, 2010 | Freezers
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero Model 550 (1992) freezer drawer doesn't seal
the drawer need to be adjusted so that it will close.. with a air leak you will have frost build up around the drawer...there are drawer closers on the back of the rails... it may be broken or just pushed the wrong way...when the freezer is cold it should make that sucking sound and be hard to open ... hope it helps
Sep 19, 2009 | Refrigerators
650 sub zero that has a vacuum condenser message returns.
I have seen this many times and have fixed the problem many times. You may notice a ball of frost or ice build up in the fresh food compartment, This is because you have a leak in your evaporator coil and it needs to be replaced. It is a pretty costly repair but well worth it in consideration to what you paid for this unit or what the cost of a new one would be. Because it has less freon in it is why the compressor is running longer and causing message to pop up. Have the evaporator replaced in the section that is giving the issue and this will solve your problem with the unit.
Feb 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Defrost problem. Call repair man as this is not an easy diy project. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Refrigerators
Ice maker not making ice - repair costs?
switch the fridge off and try warming the ice maker workings up with a hair dryer.
Jul 11, 2017 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
387 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
