Question about Acer Aspire™ T180 PC Desktop
Acer ast180 speakers do not work properly the sound is echoing
I just bought an acer ast180 plugged it all in but thesound coming out of it is echoed it came new out of the box thesound levels have been manually set to 40 out of apossible 100 wats next?
    Problem Solver:
  • 18 Answers
Check the volume , bass, treble settings. Check whether u have plugged the wires correctly
Posted on Mar 08, 2008
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
Very bad echo, on my NEW Acer laptop 8730G-6945
I had this problem for months - I finally figured it out on my own...
Go to your RealTek HD Audio Manager (this is either a red speaker icon in the bottom right hand corner or if you go to 'control panel, sounds speak and audio devices, realtek hd sound effect manager)
once you have the window open, under 'sound effect, go to environment and to the right of the drop down menu, click 'RESET'.
After months of trying to fix this issue, this fixed it for me!!! I hope it does for you too!
Feb 15, 2010 | Acer 90.00012.30B Computer Speakers
Echo Problem
Try one or more steps to reduce echo:
1. In Device Settings, under Mircophone test make sure that 'Auto Adjust Audio' is checked. It automatically sets the audio and reduces echo.
2. Right click in the class window to open up the context menu. Click Settings in the menu. Macromedia Flash Player Settings window opens up. Click on microphone icon and check 'Reduce Echo' option.
3. Uncheck boost in microphone device settings.
4. Use a headset and not desktop speakers.
If a class participant (may be an attendee or a presenter) is experiencing echo then all other class participants are required to make settings at their ends. Preferably, the presenter may transfer control to the attendees one by one and identify the system generating echo.
Jan 16, 2010 | Acer 90.00012.30B Computer Speakers
Audio problem
if it has a microphone you may be having you're microphone echoing whats coming out of you're speakers to disable it
windows vista:right click the speaker in you're tray click recording devices and click disable
windows xp:rigt click speaker icon in you're tray and click open volume comtrol and mute the current microphone
or if that's not the problem you may have to download new sound card drivers i can help you with that too!
Mar 11, 2009 | Acer Aspire 5735 Notebook
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
I have an acer laptop and i have an echoe in my sound... im not sure what the problem is. there is an internal mic i believe. help please! lol
Try right clicking on yout Volume Icon in the system tray (where your clock is). Click on Open Volume Control.
Make sure you have some audio playing, then just go through each channel and mute each one, 1 by 1 until the echo has gone.
If that don't work, then again, right click on Volume Icon in Tray, click on Adjust Audio Properties, then under speaker settings, select advance, then choose Desktop Stereo Speakers, under the Speaker Setup Options.
One of those should work. If it is your Mic causing the Echo, then you would get loads of feedback if you whack up the volume. If you don't get the feedback, then it's more then likely the Speaker Setup or some Sound FX is enabled through your Sound Card Software.
Dec 02, 2008 | Acer 90.00012.30B Computer Speakers
HP vs 15 the built in speakers echo
Do you have a microphone? If you do, and it is near the speakers, it will echo a lot. Also, check your soundcard settings. If there is an option for room ambience or environment effects, make sure you have them disabled.
Jul 14, 2008 | HP vs15 15"LCD Flat Panel Monitor
Help with Sound
I cannot say directly for your particular model. I will give you a generic answer that can apply to most any computer.
If you hear an echo, look carefuly thorugh the setup for the sound card. Look for anything to do with special effects.
Look for the options or properties that have to do with the sound card that is in the computer. Many of them have special effects capability.
Jerry G.
Apr 19, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire™ T180 PC Desktop Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
