Question about Kitchen Ranges
Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug. of 2007. Drawer is not working proper and Maytag says it is fine??? What drawer can not be used my last Maytag bottem drawer did not do this.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
Posted on Mar 08, 2008
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
Where can I locate the details of the oven eg. Make Model etc?
gee on a tag/sticker on the back possibly on a metal plate in the oven or bottom drawer my maytag is along the left side of the range bottom drawer outer frame
Mar 17, 2015 | Ovens
Oven door dirty between glasses
Usually there is a spot right before close that the door wool slip off the hinge. On some models you use a nail to hold it on place some have a special hinge. After that the door comes off and a few access gives you access to the inside panel
Sep 13, 2014 | Maytag MES5752BAW Slide In Electric Range
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My gas oven doesn't work but the stove part does. The product is only 2 years old.When I put the Bake or broil button on the oven doesn't heat up. I am sure the pilot light is out but I don't know how to...
To answer the question fully, I'm gonna need the model number. Pull out the bottom drawer, and the model should be located on the side of the frame or on the drawer itself. Might even be behing the oven at the top, should be a metal plate that flips up.
Feb 21, 2011 | Maytag Ovens
Left front element transfering heat to frame. Top side and front of frame are very warm to touch. Should I refrain from using that element until it can be check? Is there a danger of electrical fir
There is usually a door seal around the oven door if its gone or out of place this is most likely the problem. 1 other thing is that Insulation can be moved around (not meaning to offend just stating facts), insulation can be moved around by rodents, or if it happened to get wet it could shrink.
If either of these help you undersatnd and find your problem please rtate me as high as you can. Thank you for using fix ya.
Apr 28, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Storage drawer - design flaw?
yea find it hard to believe that a product would be built this way!!, without looking at it would imagine that the tracks going back on both sides are too close together, which usually happens when the unit is mishandled upon delivery, a quick call to an authorized servicer will correct problem( it is a warr issue any way, and from the sound of it hell have a lot of warr work in your development
Mar 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Kitchen Ranges Logo
350 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
