Question about NetGear WGR614 Wireless Router
Got a new modem so i decided to re-setup my wireless netgear router again. ive done everything the manual has said multiple times and everytime all i get on the LED display are the power light, internet light, and LAN light. the wireless light doesnt come on and therefore i have no wireless internet. does anyone know a possible reason as to why and how i could fix it? thanks
  • bsktballer Mar 08, 2008
    All of the cables were connected they way they should be and according to the computer that is going to be using the wireless...internet still wasn't connecting.
    I have everything set up back to my old connection without the router for now.
    Scholar:
  • 47 Answers
Step One: Reset the Netgear Router.
How To :
Behind the router there is a steel mesh, near the antenna mesh there is a small button insde the mesh by use of a pen you can press that button please disconnect all cables before you commence the procedure and only the power cord to be plugged in. Press the button for 10 Seconcds and then release the button.
Do not connect the internet dsl cable till the congigration is complete.
Step two : Disconnect the power cable for 3-4 seconds and plug it back in.
Step three : plugin the router with your computer/laptop with the help of the cable. use port 1.
Step Four : open the web broweser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the cnigration to come on the right side.
3) in setup section on the right side please click on basic settings and configure as below:
a) Does Your Internet Connection Require A Login?
Answer : No
b) for the next three options its the first choice should be like that from default, if not please set all to automatic.
Then,
Click "Apply"
4) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on LAN IP Setup.
a) In LAN Tcp/ip setup change the ip address to : 192.178.1.1 (to avoid dsl ip conflict)
b) there should be a check on use router as DHCP Server.
Starting IP Address 192.178.1.2
Ending IP Address 192.178.1.7
(the ip range should not be more that five ip address as otherwise the performance output would be pathetic)
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Posted on Mar 16, 2008
    Problem Solver:
  • 8 Answers
Is all the cable connected? Is the ethernet cable or broadband cable all connected?
Did you check if your wireless internet works. My friends router indicator for the wireless died but the wireless connection has no problem. If that does not work try to get a different modem and try again. If it still does not work you may have to get somebody to set it up for you.
Sorry that i can't be much of a help.
My father is much better at this kind of stuff than me.
Posted on Mar 08, 2008
  • Hitokirihaku Mar 08, 2008
    Oh yeah one more thing...Do you have a cable modem?
    Try checking that to see if it is the problem.
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Ive lost my password on my laptop and reset my router to factory settings. So now my dell 1410 vista tells me it wont connect to an "Unsecure" network. Can i reset my laptops password for the...
1. you will need the original CD to setup the router again and set a new password for the router.
2. go through the set wizard which will prompt you with additional steps to setup router and other wireless devices
you will need to contact your provider for additional help such as ip address and ssid information.
Jun 13, 2011 | NetGear WGR614 Wireless Router
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I ordered a wireless router so I can hook up my PS3. My computer is not compatible with wifi so I thought I'd just leave it hooked up to the modem. The instructions tell me to put the CD into my computer...
You have to use the computer to insert the CD
As your computer is not wireless compatible, you can have this connected to the router itself on the wired connections and use PS3 on wireless
Do NOT connect your computer to modem and also Netgear to modem.
Either one of them won't work. Instead connect modem to Netgear and computer to Netgear with an ethernet cable.
After this type of connection is made, try to setup the router with the CD inserted into computer.
This is how things work!
Jan 22, 2010 | NetGear WNR1000 Router
Setup Wizard says theres a problem connecting to network device
with a new router I would suggest to to start from scratch and do it manually, here's the manual
and I strongly suggest you give netgear a call if the manual setup does not work. feel free to post back although do it after following the manual setup instructions on page 11.
also provide more info like, isp and operating system and we'll try to help out.
Dec 24, 2009 | NetGear WNR2000 Wireless Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
NetGear WGR614 Wireless Router Logo
126 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
