Wiring sub on home theatre
I cant get my sub to work on stereo. There are two different plugs on receiver. Sub pre-out And subwoofer. What is the difference. Also on back of sub there is two different sets of plugs. In and out right and left. Which one do I use.
  • 492 Answers
Use the sub pre out and wire it into the left input on the sub.
Posted on Mar 08, 2008
How do convert my active sub to passive sub speakers
Disconnect the subs amp from the driver. Run wires directly from the driver to whatever amp is now powering it. If the drivers impedance isn't too low, that should work.
What won't usually work is a one or two ohm car woofer on a home stereo/ theatre setup. The impedance is too low.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 10, 2016 | Audio Players & Recorders
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
How do i connect my subwoofer to my home theater
Easy. Your home theatre amp will have a sub or LFE output ( RCA plug ). You simply connect this output to the input ( usually the left side, or use a Y splitter and use left and right inputs, or the LFE input if your sub has it ). Then, you must turn the sub on in your recievers setup menu, and your sub should work.
Mar 03, 2013 | Sunfire True Sub MK II Subwoofer
I have a Jensen KS212 and I'm connecting it to a home theatre receiver direct to see if it works but nothing comes out of it. Does this mean the sub is not working or there's not enough power from...
Hi, welcome to FixYa..
Your subwoofer requires a seperate amplifier that has low pass filter in the pre out system, which means it will allow all low frequency signals from the input section of the amplifier/ crossover. Your receiver has combined signals of high, mid and midbass signals that will not be able to drive your subwoofer. That is the main reason why some receivers has "Subwoofer Out" to allow you to use "Active Subwoofer systems" (also known has self powered or has a built in amplifier w/ subwoofer)
For you to use your Subwoofer, it must have a seperate amplifier, connect it to Sub out of your receiver and from there you can hear the difference. Hope this helps.
Jul 13, 2011 | Jensen KS-212 Car Subwoofer
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Subwoofer pre-out wires
Sorry for the stupid question but is your subwoofer a powered sub? The subwoofer out is just a preamped signal that drives a powered subwoofer. Let me know then we can go from there.
Jan 28, 2010 | Audio Players & Recorders
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Have an existing ts-1100 home theatre infinity speakers
You cannot use this system with one that does not have a Subwoofer or LFE (Low Frequency Effect) output. Unfortunately, this sub doesn't have a line-level (speaker wire) input. Sorry.
Nov 20, 2008 | Infinity TSS-1100 System
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
234 people viewed this question
 Grubhead
Grubhead
