Question about Kenmore 30169 Electric Single Oven
Oven door on lock
While using the oven the latch on the door went to lock. we think it happened when we were checking the food half way thru. at this point the latch on the door is sticking out and the door will not close all the way and we can't use the oven. oven is currently off. After cleaning the door stays locked????
    President:
  • Kenmore Master
  • 2,651 Answers
Is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Posted on Mar 08, 2008
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
OVEN DOOR LATCH BLOCKS THE OVEN DOOR FROM CLOSING ALL THE WAY. I CANNOT GET THE DOOR LATCH TO RETRACT.
Hi
There could be couple things. First, try pushing the door closed as you turn the handle. The latch may have dropped into the strike hole completely, binding the latch. Or you may try lifting the door as you try and open it. Friction is the one thing that most often happens causing a latch not to retract.
Another possibility is that the latch may have become detached from the knob set. If this is the case, you will have to remove the lock from the door, and from there you can open the door with a flat blade screwdriver. I recommend replacing the latch as well. If you remove the lock from the inside of the door, using a flat blade screwdriver you can pull the little 'T' that sticks out from the latch on the inside of the hole. This pulls the latch back away from the strike, allowing you to open the door.
There are different configurations of latches, and they activate like way. You could run into a long latch the lock runs through. You can use a large flat blade to activate that. If you have the type with the half moon, use the outside of the lock body, stick it into the half moon, and turn the whole thing to retract the latch.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | KitchenAid KEHC309JSS Electric Double Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door stuck
To open the door, raise the oven top and use a a flat head screwdriver to open the lock manually.
The door will still lock itself when you close it, so this is only usefull to get your food out.
Oct 19, 2008 | Amana AEW3530DD Electric Single Oven
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Oven door on lock
try switching power off to unit by switching breaker of and on.if this does not work you will have to remove oven and remove rear panel or top panel and disengage or relpace latch assembly.only if your a tech.
Mar 18, 2007 | Kenmore 30169 Electric Single Oven
Kenmore 30169 Electric Single Oven Logo
195 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
