Forgot code for 1996 acura integra dolby system 3403
SOURCE: Radio code for Acura Integra
Well, ive solved my own radio problem LoLz! On my 1996 Acura Integra LS-S the serial number is located on the back of the radio. The dealership told me to bring it in and they will remove my radio for $9O. That's ridiculous.If you can remove it yourself then you save ninety dollars. Or just do what i did...I squeezed my lil a** under the steering wheel and peeked behind the indash thingy where the radio is held and with a flashlight i was just barely able to see the serial number. I dont know if the serial numbers are all the same for all the makes, models and years like mine. But heres what i got. The serial number is: PH22481 the code for the radio is 26162. I called my local Honda dealer and gave the serial number and they gave me the code over the phone. If it doesnt work try disconnecting the battery for about 6O seconds and try again. Good luck and i hope this helps. FOR I FINALLY HAVE MUSIC!!!! YAY!!!
SOURCE: 1996 acura integra idle surging?
Check this out, http://www.hondahookup.com/forums/showthread.php?t=147179
Step by step guide to diagnosing idle issues on your honda.
SOURCE: color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
SOURCE: need 1996 acura unlock radio
I had to have my radio pulled out to get the code from the bottom of the radio. There was no note in the manual about the code. Then I had to take the code to the Acura Dealer to phone it in to the factory to get the code to unlock the radio's reciever ability. It cost me $50 to have the radio pulled out to get those numbers from the bottom of the radio, but the Acura Dealer used those numbers to get the radio working for free. I had to take my car into the Dealer to get it done.
On the small ctrl panel there is written ''CODE'' and the unit is not working at all, not the radio, not the cassette player. Dismantled the antenna assembly but no fault found.
[email protected]
