Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Humming i have a zenith 57' and it starts to hum while where watching it if we hit the back of it, it stops but then starts up again my picture is fine just the humming is annoying what can it be and how to fix it
  • hummed out Mar 08, 2008
    thank you for your help sarskie i took the back off and i unhooked the speakers and it stopped plugged one in @ a time and it working great i dont think they were pushed in all the way thank you for your help:) .....TY
    Problem Solver:
  • 9 Answers
Gud day..may be there is a lose of connections or corroded solder...check also for connectors and thigthen it...you said if you hit at the back it will back to normal..may be there is a loose connections..ty
Posted on Mar 08, 2008
I have 2002 dodge durango no noise or humming in park putit in reverse it has a humming noise hit gas noise stops put in drive noise starts again apply gas noise stops again anysuggestions please?
Check the transmission fluid level and condition. If the fluid level is off, correct it and then see what happens with the noise. If the fluid is discolored you should change the fluid and filter as a plugged filter can cause a noise.
Apr 08, 2017 | Dodge Cars & Trucks
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Why won't the fuel pump shut off
Fuel pump won't be the cause. Most likely the relay.
Apr 06, 2017 | 2005 Mazda 6
2005 model Zenith 50inch DLP YV makes a very loud humming noise when it is turned on. lamp in on but no picture
Vacume out where the fan is in the back of the tv. That should release alot of the built up dust. I try to do that to my tv atleast once a month. Hope this helps.
May 29, 2011 | Zenith Televison & Video
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
White Westinghouse flat screenTV freezes up and hums.
Sometimes if you just press on your overscan button on the remote and make the picture a little bigger or smaller the humming noise and freezing of the picture will actually stop.
Jul 27, 2009 | Westinghouse SK-26H240S Television
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
