Question about Dell Dimension™ 4600C PC Desktop
No Master drive 0 found
This computer starts up and goes directly to BIOS for drive configuration.
When BIOS is set I get a No Primary Master Drive 0 found.
It does see the CD/DVD drive as Secondary master.
Could the Motherboard be the culprit and just not be spinning up the HDD?
Had a power issue and replaced the PS with new OEM.
Pulled the battery and held Power button for 30 sec. and it did try an auto setup next Boot up try.
  • cpcca Sep 10, 2008
    I have 2 Dells with the same problem. Dell Dimension D110 and Dimension 4500. Both Boot into Black screen with option 1: retry boot or option 2: setup. Option 1 just goes right back to the black screen. Option 2 opens BIOS. In BIOS no hard drives are seen.Tried booting with Ultimate boot disk in CD and am able to read hard drive content. Tried reseting CMOS per Dell instructions, tried this drive in another PC and it works fine, also tried known good hard drive in the Dell, All with same result. It just doesn't see the hard drive. Is it time to concede and condemn the motherboard? Are there Mother board haed drive drivers that need to be reloaded ? I don't have the Dell recovery disk
    Genius:
  • 1,226 Answers
Hello!
this problem is made loss connection of the hard drive, Busted battery In the motherboard, Is this new harddrive? if yes then check the jumper setting, see label setting on the hard drive. It should be the hard drive is the master. no problem with your CD rom.
solution: replace the battery in the motherboard. and fix loss connection of the hard drive. or refix all the connection inside the system.
same issue occur, try to examine the hard drive maybe maybe you have to interchange the connection of the hard drive and the CD rom. if still , then try to not connect the CD rom only the hard drive.
Failure to resolve in this solution you may either change the cable of the hard drive or change the hard drive.
best regards, melnavz
ps. don't forget to rate me good rating.
Posted on Mar 08, 2008
Drive 0 not found Serial ATA, Sata 0
Check the jumper settings on the primary hard disk drive and set to master. Also check that the cables and connectors are firmly in place.if problem persist, drive may be bad
Sep 17, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
DRIVE 1 NOT FOUND, PATA 0
One of your settings in the BIOS is set to look for a drive and it is not finding it. That is what that message means. If you have multiple drives in this machine then one of them has failed. If you only have one drive then the settings are set to look for a drive and it is not finding it. To fix this reboot the computer. When you see the DELL logo press F2 to get into setup. Then go down to Drives and turn off any drives that are set to Auto, except for your C: drive which should either be SATA 0 or PATA 0. Since it is not saying that SATA 0 is not found then I suspect your main drive is on the SATA 0 channel. Go to SATA 1 and turn it off. The instructions should be on the screen. Usually you select it by moving the arrows and then hit enter, you then use the arrows to select off. If your CD-ROM/DVD ROM is not on PATA 0 then turn it off as well. If you need more advice let me know.
Apr 28, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
Can't get BIOS settings right
First check to see if your drive (the 160Gig) is set to master or slave. If you are going to use this drive as your primary drive (boot disk) it must be set as master, and it would be drive 0. If, on the other hand, this is a second drive, it should be set as "slave, and should be drive 1. If there is an auto-detect HDD in your Bios, try that. If not, and this machine still won't detect your HDD, you may need to download and install a Bios update, because if your Motherboard is too old, it may not recognize a 160 Gig HDD.
Feb 15, 2009 | Computers & Internet
I'm getting a message saying ''primary drive 0 not found''
Either the BIOS is not configured to sense the connector where your hard drive is attached or the drive is dead and unreadable.
Start the machine and press F2 when you see the Dell logo. This should get you into the BIOS setup. Come down to Drive Information and see if your HDD is listed under IDE1 (or Primary Master). The BIOS should list the model number and capacity. If IDE1 is off or disabled, change the setting, reboot and go back into BIOS. If you still can not see the HDD in BIOS, remove it and put it as a secondary drive in a different machine to see if it comes up. If not, you have a dead drive.
Dec 30, 2008 | Dell Dimension 3000 PC Desktop
Primary Drive 0 is not found when I boot my computer
First things first use teh arrow keys for left and right to select auto for the primary drive. If when you reboot and the drive is not seen then double check if the hard drive is set to master you can see the jumper settings and how they should be set on the top of the drive itself. Then check the power if the drive feels like its vibrating then its ok. After that turn on the computer. If after that the drive is still not detected then you might have to consider that the drive is defective and i would suggest you try another drive and see if it is detected.
Kindly reply back for additional questions.
Nov 19, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Dell Dimension™ 4600C PC Desktop Logo
114 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
