Question about Compaq Presario M2000 Notebook
Touchpad not working at all
Had a little liquid spilled on touch pad and now it does't work
  • 46 Answers
Hello...i'm afraid that the pad must be replaced..but maybe you can try for now to use an ordinary ps/2 mouse connected to the rear of your computer..you must reboot...your system after connecting it..maybe also go to control panel in windows and use the add new hardware..icon...if the mouse works properly it' s. maybe a qustion of time before the pad dryes up...depending how long time ago it happened...please tell me how it went...good luck...Ron
Posted on Mar 08, 2008
Dell d620 touchpad not working
Replace the switch assembly as an ingress of liquid has damaged it.
Mar 09, 2014 | Computers & Internet
Touchpad and some keys problem
Your problem is two parts. One part concerns the touchpad and that is due to the touchpad hardware connections coming loose. The sticky key however is due to some sticky liquid seeping into the keyboard at one point in time. Maybe the laptop got exposed to a sugary beverage spill that made the keys sticky. Clean underneath you should be fine, but try not to remove the keys as you clean them because the braces that hold the keys to the keyboard base sometimes break.
Jan 16, 2014 | Lenovo G580 Laptop
Work my Quantary touch pad
Have you tried an external mouse to ensure that the pointer works?
Usually these problems are due to either a defective pad driver or a history of a spilled liquid contaminating of the contacts, or a settings issue (i.e. touchpad is turned off). Hve you trued any of these obvious problem areas?
Please provide a few more details such as Win OS version, TouchPad driver version, etc.
Dec 09, 2013 | Lenovo 3000 Y410 Laptop
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
Milk was spilled on the touchpad of my laptop the cursor moves but it won't click
You need to replace the touch pad or you can connect an USB mouse to your laptop and not use the touch pad.
Mar 21, 2013 | Dell Inspiron Computers & Internet
Spilled water on my keyboard, touch pad stopped working. Dried it ff and left it for an hour. Unfortunately curser/ Touch pad still not working and can no longer connect to the iternet, seems like the...
When this happens, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Feb 26, 2011 | ASUS Computers & Internet
Cursor moves around
You might need to reinstall the drivers for the touchpad is what it sounds like. It might be a bad touchpad as well (either broken sensor or something on the touchpad itself which looks like a finger touching it). Try removing it from windows device manager and let windows find it again.. that might do the trick. You might just try cleaning that pad as well just in case..
I had a touchpad once that I spilled liquid in it and it did this same thing until the liquid dried out. did you touch it with wet fingers or get it wet somehow?
Those are a few recmdations to try.. hope it helps you out!
Stan
Sep 19, 2009 | Acer Computers & Internet
How to clean inspiron 1525 touch pad
Hi there.
The touchpad itself is easy to clean but if the liquid has got into the left and right click keys you may have a problem, a warm soapy partially dry cloth will take the residue off the touchpad but the soda may have got to the circuit board causing it to be slow to react.
To clean the left and right keys and under the touchpad you have to take the laptop apart, remove the keyboard and the front cover and clean under that where you can get under the left/right click keys and the ribbon cable of the touchpad.
This type of job is not for the novice and i would advise having a technician do it whether it's in or out off warranty, preferably Dell themselves.
Other than that the best option would be to buy a wireless or wired mini mouse which are much easier to use than the touchpad itself.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 19, 2009 | Dell Inspiron 1525 Laptop
Mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Jan 28, 2009 | Lenovo 3000 Y410 Laptop
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
