Question about GE Profile WPXH214F
GE model WWH7602VWW front loaded washing machine
I need to access the on/off switch, how do I release the front pannel to check out this switch
  • Anonymous Mar 15, 2014
    Front load mhwe300vw11
Colud not access the switch but found the door interlock switch faulty,
Posted on Mar 08, 2008
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
Our GE washer model #: WCVH6800J1WW is overfilling and it won't wash anything we have already replaced the pressure switch and the control pannel and still nothing. Please help.
When you replaced the pressure switch, did you fully test the pressure switch hose?
Here's a similar posting that explains a potential issue and how to troubleshoot:
http://www.fixya.com/support/t8933273-general_electirc_washer_model
I highly recommend doing a diagnostic test because it's free and easy. Most of the time, the washer will self-diagnose. Check out that posting for instructions on how to do the tests.
Feb 26, 2011 | General Electric WCVH6800J Front Load...
BAD LID SWITCH
This MANUAL shows how. What you must do is remove the front panel. It is kinda tricky. Use a thin blade to release clips between the top and front panel then tip the front panel towards you and lift it out yer way. Then you can remove the screws holding down the top and get to the switch.
Jan 29, 2010 | General Electric WJRR4170GWW Top Load...
Front load shows wash but basket not moving
I FOUND A BELT POPPED OFF OF A MODEL LIKE YOURS ONE TIME. TAKE THE BACK PANNEL OFF AND SEE IF YOUR BELT FELL OFF. UNPLUG YOUR MACHINE FIRST! AND IF YOUR BELT IS OFF CHECK YOUR PULLY IT MAY BE LOOSE IF SO REPLACE IT AND YOUR BELT.
Jan 12, 2010 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Where is the belt. we have no manual
The belt is located inside the machine at the bottom. you will need to remove the front panel.
you did'nt provide the full model number off the machine. so im giving you my best shot.
use a puddy knife between the front pannel and the lide in the front right and left area to release the clips on both sides and this will let the lid come up or the pannel pull out.
you need to remove the pannel for access.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
Can I use only cold water with my GE front load washer
Just used the cold water and plugged the hit water tube. It worked.
Mar 18, 2009 | GE Profile WPXH214F
Wbsr3140d washer
you can remove the front paqnnel by using a knife and releasing the clips holding it on, there is one on each side on the top of the pannel, just take a flashlight and shine it in the crack then stick the knife in to release them, the pannel then lifts right out.
Feb 12, 2009 | GE WBSR3140D Top Load Washer
Where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Profile WPXH214F Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
