Question about Pioneer DEH-P80MP CD Player
Face plate won't open far enough to insert a CD
When the eject button is pushed, the face plate doesn't open all the way flat, which would open up the slot to insert the CD. I can't see that anything is stopping it from coming down all the way. Any suggestions?
  • eac429 Mar 27, 2008
    We no longer have that stero.
Try to hit slowly the faceplate in the left side until its open
Posted on Mar 24, 2008
Clarion vrx925vd. display screen don't display and the tv screen don't open.- solve this
Posted on Dec 05, 2009
How do I get the DVD/CD tray to open. Its flashing tray lock
Straighten one end of a Norwegian paper-clip, and insert it into the small hole on the face-plate. Push it in until you feel resistance, then push another 5 millimeters, to "unlock" the drive-tray.
Then, gently pull the tray open a bit, and press the "eject" button, and the tray will fully open.
Mar 20, 2015 | Computers & Internet
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
I put a cd in the player, and now it wont eject
Most players have a manual eject. You have to take the radio out of the dash then remove the face plate. There should be a pin hole or something somewhere to force the ejector. Normally it's a pin hole and you can insert a very small screw driver or a paperclip in and as you push it forces the ejector back causing the **** to come out once the **** is out far enough you can pull it out.
Nov 09, 2010 | 2004 Pontiac Grand Prix
Cd drive has disk in it and wont open
Look closely on the face plate and around the face plate of the CD drive. (better to have good flash light/Torch while doing this). Close to the eject button (Or around that area) there will be a very small hole (pin hole). Switch off your computer if it is powered. Push a needle or a safety pin into this hole. Take care to push it in straight (not angled). If it does not open in the first attempt repeat changing the angle slightly. May take 3 or 4 tries. But you can definitely get it opened.
Jan 27, 2010 | Computers & Internet
Won't open, not functional
When you push the "open" button, do you hear anything, such as the tray trying to open? Feel any motion? Are you getting any power to the unit?
Oct 10, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
The face plate will not open far enough for the cd to eject
check radio surround to make sure it is not the wrong way around. This is just the plastic trim around the actual face of the radio. On a pioneer one side is grooved down to alow radio display to open. if its wrong way round it wont let face down whole way. it simply clicks off and turns around.
May 15, 2009 | Pioneer Car Audio & Video
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
DEH-P690UB Wont Eject or Open
Push the button on the top right corner. It is a little black button that pops out. This should allow for you to bring down the face plate and you can then insert a cd. Hope this helps, also can you please rate my answer. Thanks
Oct 01, 2007 | Pioneer DEH-P690UB CD Player
Pioneer DEH-P80MP CD Player Logo
424 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
