Question about Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
The above model washer is working fine until the next load when it won't spin but it can fill up with water and drain without problems. i have changed the door switch without luck. what else can i do before the service come out and charge me money before he tells me what is wrong with it.
  • 3 Answers
Did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Posted on Apr 20, 2008
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Good Morning Friend,
I understand that your Frigidaire washer, model# FTF530ES, is having trouble with the drum rocking back and forth, from front to back. I suggest making sure that your washer is level. I would check from front to back, side to side, as well as from corner to corner. If you have leveled your appliance and are still noticing the drum rocking from front to back I would suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
