Toshiba Satellite A135-S2276 Notebook Logo
Posted on Mar 11, 2010
Cpus for upgrading
Need to know the type cpus i can uses for a upgrade
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
Answers
31
Questions
Helped
15626
Points
66
Hi i using ASUS P5GV-MX Motherboard i want upgrade processor so kindly give me specifications
Hello take a look here at the homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GVMX/#CPUS
Here is the list of supported cpu for the mainboard.
Your mainboard use Socket 775 for Intel Pentium 4.
This cpu type is phased out.
But you can always look for a used one.
You maybe have to upgrade the bios to support a bigger cpu.
Hope this was helpfull
You can upgrade processor?
Maybe you can upgrade the processor. For example, the U50Vg laptops come with one of the Core 2 Duo T9550/T9400/P8700/P8600/P7350/T6600/T6500/T6400/T5900/T5850 (2.66 GHz - 2.16 GHz) or the Pentium M T4200 (2.0 GHz) CPUs. The motherboard might support one of the other chips in the above list. (Probably not all - I know that some motherboards only accept a small number of closely related CPUs even with the same socket design.)
So the upgrade options would depend on which ASUS motherboard is actually in your computer. If you know the motherboard model number, add a comment and I'll check which CPUs it supports. However, to access the motherboard, you need to disassemble the entire computer (including removing several small ribbon cables from the keyboard, touch pad and display). The effort may not be worth the performance difference.
I hope this helps.
(there is a web site showing the steps to disassemble the U50V; you can find it through Google.)
Can i upgrade my cpu ? and what cpus my motherboard supports? it is an intel E945GCU
I honestly think that they are embedded on the motherboard. I know you can buy new boards with Atom cpus on-board.
You might be able to get a new mb/cpu combo as an upgrade. Look at newegg.com for boards.
1helpful
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
2helpful
Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
The following CPUs are supported by the Acer TravelMate 2480:
Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
Dual E5345 Xeon -Upgrade?
Hi there.
If you note down the make and model of the motherboard you will be able to check to see if you can upgrade to better processors and which type of processors the motherboard supports.
If you want me to source the info please post the make and model of the board.
Thanks for using FixYa!!
Need a processor upgrade suggestion
Hi
... after some quick looking around I found a few items that may help you decide ...
This is a discussion on the Apple site itself:
https://discussions.apple.com/thread/7585102?start=0&tstart=0
Upgrades:
http://www.everymac.com/upgrade_cards/by_processor/powerpc750.html
More thoughts about upgrades:
http://www.everymac.com/systems/apple/imac/faq/imac-g3-processor-daughtercard-how-to-upgrade-processor.html
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
Using music software
Here is a site that will give you info to most of your questions as far as upgrading your Mac. LowEndMac
more ram and a faster hard drive would improve your machine's performance somewhat.
Upgrade motherboard?
Hello Keith,
The present Motherboard in your computer is Asus A8AE-LE. It has a lot of upgradign options.
It will support the Following CPUs.
Up to AMD Athlon64 X2 4800+
Up to AMD Athlon64 4000+
Up to AMD Sempron 3200+
Also, it has the following memory specifiations.
Memory Installed 1 GB (2 x 512)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
Speed supported PC-3200 MB/sec
Type 184 pin, DDR SDRAM
DIMM slots Four
Open DIMM slots Two
And the PC has a PCI Express x16 slot you can install a high end Video Card along with a power supply upgrade.
So before you go ahead with replacing the motherboard I would recommend you to consider these options as we can cut down the cost to a greater extend and having the same iprovement on performance.
If you wish to upgrade the motherboard you can use any motherboard having ATX form factor [9.6 in X 9.6 in] in the computer. The CPUs should be selected according to the motherboard you have chosen.
Hope this helps
Pat
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
