Scanning 4 X 6 Photo, want to print as 8 X 10.
How do I do this.
Set your scanner to scan at 600dpi. That will give you a 8x12 image at 300dpi (print quality- your image never needs to be more than 300dpi).
Then use your favourite image editor to crop the image to 8x10. If you don't have a favourite image editor, XNView (free) will do it:
http://www.xnview.com/
-Open the image in XNView
-Right click on the image, select "Set Selection Ratio --> 5:4"
-With your left mouse button, drag a square on the image...this will automatically scale so it chops the unwanted 2" off
-When the square is selecting the bit you want to keep, select "Edit --> Crop"
-Then we need to change the image from 600dpi to 300 dpi:
-Select "Image --> Resize"
-Uncheck the "Resample" and "Keep print size"
-"Keep ratio" should be checked
-Change the 600 in the "Units" box to 300; the setting unit should be "Pixels per Inch"
-Print
