Vector Stormtracker Elite
I am unable to program our Vector Stormtracker Elite (WC3000DSV). I have programmed everything the instructions say to do, but the weird part is that it says the dial must be turned to Weather in order for the weather alert feature to be used. If I turn the dial to Weather and leave it on all the time, I hear the weather stations. I thought the whole purpose of a weather alert radio was to alert you even when the radio is in off mode. Can someone please help? Thanks.
Click on the mute button while WEATHER is selected on the dial. This should MUTE audio and ALERT will appear on LED. Then you will only hear ALERTS.
Posted on Jun 05, 2008
Vector stormtracker elite wc300dsv manual
www.listia.com/.../1452486-vector-stormtracker-elite-wc300dsv
Apr 13, 2014 | Vector Vehicle Parts & Accessories
Looking for manual Vector Stormtracker Elite, model WC300DSV
Black & Decker took over Vector. The manual can be found at http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/WC300DSV.pdf .
Feb 18, 2009 | Vector VEC136 TV Receivers and DVRs
Logitech Elite Keyboard manual
i need instruction on how to program it
Sep 10, 2008 | Logitech Elite 967234-0403 Keyboard
Manual
Hi, not sure why the manual I uploaded doesn't show up anywhere so here it is in 2 posts (too large for 1 post)
Stormtracker Vector Model: VEC438 Classified: UNOFFICIAL USE AT YOUR OWN RISK!
Programing Instructions
To Program Alert:
Turn the radio on and then press:
1. Menu button (may have to hold it a few seconds) and Alert should show in the Display.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the Menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the Menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the Menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the Memory button is pushed, the alert will not activiate.
To Program County
1. Menu button (may have to hold it a few seconds) and when ALERT appears, tap Menu button to scroll to County.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: All/Multiple/or Single
3. Then use the Menu button to select between All/Multiple/or Single (You'll need to know the S.A.M.E. codes for the area you want to listen to, otherwise select ALL and you will recieve "All" Statements, Watches & Warnings without having to select a specific County).
4. After making your selection, press the Memory button to the left of the Menu button if ALL was selected or Channel/Snooze button to the right of the Menu button if you chose Multiple or Single (You'll see CODE01 on the display) If you chose Multiple use the Menu button to choose which Code Position to enter (01-10) then press the Channel/Snooze button to the right of the Menu button. Enter the first digit of the S.A.M.E. code then press the Channel/Snooze button to the right of the Menu button to move to the next digit of the S.A.M.E. code. Repeat this for all digits of the S.A.M.E. code. Then press the Memory button to the left of the Menu button to lock in that code. Press the Menu button to select the next code position to enter. Then press the Channel/Snooze button to the right of the Menu button, then the Menu button to select the digit of the next S.A.M.E. code to be entered. Repeat these steps as necessary to enter in all the S.A.M.E. codes you wish to enter, each time pressing the Memory button to the left of the Menu to lock in each code position. When completed entering in all S.A.M.E. codes press the Memory key again to lock in all codes and return to normal operation. This completes the programming of the County Code function.
Example:
COUNTY SAME # NWR TRANSMITTER FREQ. CALL SIGN WATTS
Fulton 013121 Atlanta 162.550 KEC80 500
Colquitt 013071 Pelham 162.550 WXK53 1000
Colquitt 013071 Valdosta 162.500 WWH31 1000
NOAA Weather Radio Frequencies
162.400 MHz (WX2)
162.425 MHz (WX4)
162.450 MHz (WX5)
162.475 MHz (WX3)
162.500 MHz (WX6)
162.525 MHz (WX7)
162.550 MHz (WX1)
Channel numbers, e.g. (WX1, WX2) etc. have no special significance but are often designated this way in consumer equipment. Other channel numbering schemes are also prevalent. Best to just tune to the strongest sounding station in your area, this radio does not display frequiencies, only channel numbers.
NOAA Weather Broadcasts
Channel Frequency
1 162.550
2 162.400
3 162.475
4 162.425
5 162.450
6 162.500
7 162.525
A link to get the S.A.M.E. codes for your listening area: http://www.nws.noaa.gov/nwr/indexnw.htm
Aug 18, 2008 | Vector VEC438 AM/FM/Weather Radio
Stormtracker
Here is the manual..from some obscure Black & Decker/DeWalt (the new owner of Vector) site:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC438.pdf
-Jason
May 10, 2008 | Vector VEC438 AM/FM/Weather Radio
297 people viewed this question
 Grubhead
Grubhead
