Question about Samsung LN-T4671F 46 in. LCD Television
Image cut off of Samsung LCD TV picture
The top and bottom of the picture on my Samsung LCD TV are cut off. have tried adjusting the image size, but there are only 2 options--full, widescreen or a square in the center of the screen. ??? Help!
  • 3 more comments
  • Anonymous Jun 21, 2008
    He's right! The # button did the trick and fixed my picture cut off issue! thanks so much
  • seth613 Aug 18, 2008
    I have the same problem with my Samsung 52 in LCD Television. The top and Bottom are cut off at least 1 inch on each side.
  • Anonymous Sep 06, 2008
    my picture is cutoff and tv wont adjust back
  • Cameron98 Sep 23, 2008
    the top and bottom of the picture on my Samsung LCD TV are cut off. have tried adjusting the image size, but there are only 2 options--full, widescreen or a square in the center of the screen. ??? Help!
  • klabudzki May 11, 2010
    I have a picture cut off at the bottom of the screen by 1/4 on my Toshiba portable TV. I have used universal remote control, Philips, as I do not have original Toshiba one.
    This did not work. There is not many buttons in front of tv, just volume control and channel change button .Could you help?
    Regards,
    Kris
    Genius:
  • 1,554 Answers
If you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
  • yardsaler320 Jan 30, 2011
    actually...instead of pressing the # sign, we pressed the asterisk, and it worked!!
IF YOU'RE USING A TV CABLE BOX, USE ITS REMOTE TO ADJUST THE PICTURE, NOT THE SAMSUNG REMOTE. CHOOSE "NORMAL", AND YOU'LL SEE EVERYTHING THAT'S BEING BROADCAST.
GOOD LUCK!
Posted on May 02, 2008
My Samsung TV squashed the image. I have basic cable, no HDTV. Is there an adjustment for this.
Posted on Jul 28, 2008
Yes you guys saved my life!
Posted on May 20, 2012
THANK YOU ... my cable was on zoom and it was an easy fix!!!
Posted on May 04, 2008
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
My new lg 3d tv is closng on top bottom and sides is there anything i can do to cure the problem
Could you provide more information? What do you mean when you say, "closing?" Do you mean there is a black band around the picture? If so that means the original picture is recorded at a lower pixel density than your TV will display.
In the past most TV program signals provided a picture dimensions (in computer standards) very roughly 600 pixels wide by 400 pixels tall. What this means is that a picture of that pixel size will display as a small, squarish image slightly wider than it is tall on a (now) standard 1080p LCD television--which produces an image 1920 pixels wide by 1080 pixels high.
That would be nearly unwatchable (picture too small) except for the fact that most TVs compensate for the relatively small size of "standard definition TV (SD TV, as opposed to HDTV) by enlarging the image so that the top and bottom edges of the picture touch the top and bottom of the TV screen. This will leave black bands on either side of the picture. Some LCD TVs will automatically stretch BOTH dimensions of the image, which yields a distorted, "sqaushed" image.
All my comments above apply to both standard LCD and 3D-LCD TVs, by the way.
A more precise overview of the facts about TV picture size can be found here:
http://en.wikipedia.org/wiki/Display_resolution
Nov 23, 2013 | LG 42LW5300 42 Class 3D LED HDTV
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Sony WEGA KV-27FS100 picture size
hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung LN-T4671F 46 in. LCD Television Logo
8,684 people viewed this question
Henry  Thomas
Henry Thomas
