For a while before this problem began i had noticed some slight discoloration on the right side of my screen but didn't think much of it. Now, however, about 2 inches from the top of my screen a line will come up and everything below it will go completely black, and if i leave it long enough, sometimes it will slowly go white. However if i flex my screen back and forth and apply pressure to the top left side of my screen it will usually come back up again and work like normal. what do you think the problem is?
Only thing i can say is this. Try to get a new screen because from what you are describing. I believe that the monitor is damaged inside. If you got the laptop recently i will suggest that you get it returned for a different one.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A105-S4004
All SMART tests suggest no problems. However, when I try to use Gparted to resize Windows partition...
(More)
All SMART tests suggest no problems. However, when I try to use Gparted to resize Windows partition in order to load Ubuntu I get a message that the hard drive is dying! Reallocated sector count is 131,007 and reallocation event count is in 400 millions. Do these measures indicate hard drive is dying and should be replaced, dispite SMART and online scanner results of status OK?
My Toshiba satelite has done this 2 times now I was on-line and for no reason I got a blue screen...
(More)
My Toshiba satelite has done this 2 times now I was on-line and for no reason I got a blue screen and then it shut down. I tried to reboot but I get 3 lights on the key board and the power botton light up it sounds like it is thying to boot then the lights flash 4 times then powers down?
I have an A105-s4211 and the lcs screen is messing up, it'll fade out to a cloudy black screen, but...
(More)
I have an A105-s4211 and the lcs screen is messing up, it'll fade out to a cloudy black screen, but when i press on the side of the screen and the front to sort of bend the screen the picture comes back on and works perfect, but asoon as i let go, it stops working and slowly goes back to the cloud, any idea's what might be the problem?
