Computers & Internet Logo
Posted on Mar 11, 2010
When I turn on our Toshiba laptop the screen is black. The Toshiba name comes on the screen but then goes blakc. The power appears to stay on.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4091
Points
33
The inverter below lcd panel will be faulty,replace with the same part number
ravishankar c.k.
When turn on Screen goes black and keyboard is locked
try boot using a bootable cd, if there is no screen appearing you may need to check you laptop motherboard and power supply .
While im using my laptop the screen turns black and only the power buton stays lit
The plug is loose in the back where the power cord is
Bend the power cord up or down until it comes on and stays on!
My screen shuts off but the laptop itself does
Try putting on an external monitor, if the external monitor stays on while the laptop lid goes out, your laptop monitor (lid) is going out (yes it happens quite a bit).
If the external monitor goes off also, Check all your power settings and video settings for the laptop (power setting can be found with the screensaver section of the desktop settings) - if all that is as it should be - it means it is your video card, and since the video card is mounted (intigrated) on the motherboard, there is not much more to do than replace the motherboard or get a new laptop.
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Laptop
Hi, according to what I understand his equipment it operates well, only that the screen appears in black, does not show anything on the screen, though the equipment operates well, it is possible that the fault this one in the FL Inverter, that is the inverter of current of the screen, which gives the take-off of the lamp of back light, the same one is in the low part of the screen behind of wave mask of the screen
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
TOSHIBA SATELLITE L40 SCREEN SHOWS A FUZZY TOSHIBA LOGO AND GOES BLACK
change your flexible wire (vga) connected from board to the screen, also change your module, the module is at the rear of the screen.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
