Question about Macally 1 Bay phr-250a (PHR-100A) USB 2.0 External Drive Case
Blue light is not working
I have a phr-100a. I had to re-install windows and now the nice blue light does not shine. did i do something wrong?
  • 85 Answers
What is this?? Is the drive internal, or by the blue light I assume you mean it is external. Is the blue light really all that nessesary? If you need it to shine (and I assume you just WANT it to shine 'cause it's PRETTY) then try installing any software that came with it, and by the way, what brand is this?
Posted on Mar 15, 2008
I have a beyond micro PHR-100A Hi-speed USB external drive. I was writing a large file when my computer locked up. I had to hard reboot. When I turned it back on, the drive light went red, made a clicking...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jul 28, 2010 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Vehicle: '97 Nissan PU, alternator
ok we have four connections at the alternator( black wire is ground) (white with blue positive direct from the battery)
and two wires connector in the regulator(yellow with black that goes to charge indicator the red light and goes to fuse 7 10a fuse block inside) the blue with yellow goes to fuse 65- 7.5a in the left fron engine comparment fuse box))#1 check for ground at the black wire= #2 check for positive at the white with blue wire (allwas with power) this wire is protected with 100a fuse is in the left front engine comparment fuse box,
remenber== check the 100a fuse
and the two fuses that protect the regulator.
when you turn the ignition switch to the on position power goes to the alternator by the yellow black wire and activate
the alternator to work.
Mar 13, 2017 | 1997 Nissan Pickup
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Label, envelope and phr lights flashing.
Check the connectors between the keyboard and PC board.
DickyO
Apr 10, 2009 | Lexmark Wheelwriter 3000 Typewriter
PHR-100A Is not working anymore
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Feb 08, 2009 | Macally 1 Bay phr-250a (PHR-100A) USB 2.0...
PROBLEM WITH INTERNET CUBE
what programs do you need to install on it?
Dec 20, 2007 | LG Shine KE970 Cellular Phone
Macally PHR-250A
There should have Quick installation guide and CD with manual inside.
You may download the manual from http://www.macally.com/EN/Techsupport/Manuals.asp
Feb 13, 2007 | Macally 1 Bay phr-250a (PHR-100A) USB 2.0...
Macally 1 Bay phr-250a (PHR-100A) USB 2.0 External Drive Case Logo
216 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
