Question about Samsung RS2630WW Side by Side Refrigerator
Samsung fridge RS2630SH, side by side, icing up on freezer.
Hi, I work on my samsung fridge, RS2630SH, ice up built up on freezer side panel, then it stopped cooling, defrost it, happen again often one or two weeks, I am thinking something wrong with control board or temp. sensor, I measured resistance of sensors (two), one is around 6500, other one is 3500, are they OK? can you please give me more details on checking board or sensors, thanks a lot.
  • KateJaz Jun 10, 2008
    Had the same problem with same model. Best Buy service tech tried new board, new sensors, new ice make, etc and nothing fixed it. Finally today, they said "it's a lemon" go get another refrigerator!
  • Anonymous Mar 23, 2014
    defrosted bot have the same issue a week later
  • 236 Answers
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ice maker has stopped working and auto defrost does;nt seem to be 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
kjffkjk
May 20, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
Jun 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker
you need to connect the ice maker to a household cold water source.  the connection point is on the outside back of the fridge.  Hook up kits are available from Home Depot or Lowes
Mar 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
463 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
