Mitsubishi projection #vs-50707
The tv works but has lines on top also when ever i use picture in picture the lines go crazy thru the screen then i have to unplug it to make them go away ???
    Problem Solver:
  • 9 Answers
Gud day.. you need to bring that on the shop.. there is a problem in the PCB, particulary in its vetical section.. .. if you continue to used that, the problem become bigger..hope i help u w/ ur probs..ty
Posted on Mar 08, 2008
Black lines moving from bottom to top on mitsubishi vs 50707
Possible that the fault is thermally related and if you can check and see the stage which changes the fault when it is warm , you can confirm by using a heater on the specified area which is warm after cooling and if the fault corrects, then the component can centered and confirmed by this method. It can be faulty capacitors, drivers or even poor solder joints.
Oct 31, 2011 | Mitsubishi VS-50707 50" Rear Projection...
Lines on screen and picture is green
Sounds like your RGB lights in the back might be out of alignment. You need to call a tv repairman who can come evaluate the situation, he should also be able to give you a quote on how much it will cost to fix it.
Mar 05, 2011 | Mitsubishi VS-50707 50" Rear Projection...
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi vs-50707
The problem could in the 9Volt, and 3 Volt regulator supplies.
Replacing C2P05 (100ufd. @ 16 VDC), and C2P08 (also 100 @ 16 ) might fixed problem. They are located near IC2P01, and IC2P03.
The numbers(C2P05, C2P08) means the place where to find the parts that need to be change.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi TV
run from it bring to shop you would not sit in front of atrain blowing its horn
Feb 27, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
