Question about iRiver X20 MP3 Player
Earphone plugin Can't work properly when you put the earphone in, the sound does not work.
  • Anonymous Mar 19, 2008
    i bought a mp4 player 2 months ago through net when i brought the player it was working fine but now it has totally changed its keys are not working properly and earphone socket also not working properly . When I [put my earphones into my mp4 u have 2 fiddle alote to get them in right so I can here...
  • Anonymous May 27, 2008
    i have the same problem with my iriver X20 i have to fiddle with it to get it to work and even then if i move a little it stuffs up
  • 49 Answers
To all three it may be that your earphones aren't working! try it on another audio product you know... if it doesn't work get new earphones!
if not it may be the audio format... try changing it to a format the X20 can read! (mp3 and wma should work)
if its neither you're out of luck. the socket is probably the problem. if its in warranty you might get lucky and they send it to be repaired. if not really bad luck there are few specialised stores with the knowledge to repair an iriver...
Posted on Jul 31, 2008
SOURCE:
Have my earphones on but can not hear music
You could try using your earphones with another device to see if they are working properly. For example, I think my earphones have a broken wire in them because when the earphone plug revolves up or down in the jack the sound cuts out. When I turn the plug around a little, the sound comes back. (I am sure you had the volume turned up :)
Jul 09, 2014 | SanDisk Sansa Clip MP3 Player
In my nokia n900 cell, i have a issue in earphone.its earphone is not working properly as i can`t getting sound more ,as i m putting full volume so i dint understand that is the issue with earphone or with...
Dear, in your mobile just play an audio without your ear phone, then increase or decrease its volume if it get increased or decrease then their is no problem in your mobile.
then again put your ear phone to your mobile, and trying doing the same thing, if it does not getting increase or decrease then surely their is a problem in your ear phone.
change your ear phone either from nokia care or some local mobile accessories store.
regards!
Jul 30, 2011 | Nokia N900 Smartphone
Cant hear nothin out my samsung shg-t239 because it says remove earphone, but i dont know how... it must be something in da settings that i hav'nt mastered yet so could you help me make calls again...
Hi
You can't remove your proper, Now put your earphone and start the player, now you hear the music, and sound, now off your music play and plug out your earphone, now surely you get the sound.
Good Luck
May 21, 2011 | Samsung SGH-t239 Cell Phone
I plug in my earphones(with microphone) but the sound keeps on coming from the notebook and not the earphones.
Hi
I think it sounds like you may be putting the earphones into the wrong soacket
can you try plugging into the other socket please and see if that works
Feb 17, 2011 | Acer Aspire One PC Notebook
My Philips GoGear Raga 2GB is not working properly. Its earfone jack socket is causing some problems, it doesnt give proper sound now!
The fault could be the earphone, check the earphone in a different device/player, if the fault still appears the the earphone is faulty, probably a broken wire in the cord.
If the earphone is OK then the earphone socket in the MP3 player is faulty. If may be too expensive to repair, unless you can DIY.
Sep 14, 2010 | Philips Audio Players & Recorders
Earphones wont work on dell computer/vistas have to restart computer to go from sound to earphones . how do i fix this
first check you connected the earphone properly. earphone has two wire. connect earphone green wire where you connect the speaker.
Jan 22, 2010 | Dell Inspiron 531s Desktop Computer
I need Help!! Plz Help Me!!!
The phones are probably not reaching the bottom of the connection where the MP3 is told to stop sending sound to the speaker.
Test with other phones.
If the problem persists, a firmware update would be a good idea.
Cheers
Jun 20, 2009 | Laser MP4-V970 MP3 Player
Why the earphones are not working properly?
that happens to those ones all of the time that model is crapplily put together if it is under a warranty i would just return it
Jan 08, 2009 | SanDisk Sansa Fuze MP3 Player
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Fit new earpiece
with N70 u can put ur earphone at the bottom of ur handset, it must be a pin kind of structure which u have to properly put in the socket.everything else is the work of earphone,
Oct 22, 2007 | Nokia N70 Cellular Phone
iRiver X20 MP3 Player Logo
64 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
