Connect to the Internet
The first step is to connect your Xbox 360 console to your Internet connection. Here's how:
Plug one end of a network cable into a port on your router or gateway. You might need a long network cable, depending upon on the location of your router or modem.
Note If you do not have a router, you can plug the network cable directly into your modem.
Plug the other end of the network cable into the back of your console.
Verify your setup
Your setup should look similar to one of the following:
Router connection
Your Xbox 360 console and computer are both connected to a router. The router is connected to a modem, which is connected to a cable wall jack. Modem connection
Your Xbox 360 console is connected to a modem, which is connected to a cable wall jack.
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection. 2. Turn on your xbox 360 and go to the xbox live tab. 3. Go wher it says Join and follow instructions. You can put your credit card info. or buy a prepaid xbox live card
Before you
connect any cables, turn off your router, modem, PC, and Xbox 360
console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem
and the other end to the Ethernet input port on the back of your
router.
With another Ethernet cable, connect one end to one
of the router's Ethernet output ports. Connect the other end to your
PC's Ethernet port.
With the third Ethernet cable, connect
one end to another of the router's Ethernet output ports. Connect the
other end to the Ethernet port on the back of the Xbox 360 console.
Turn on your modem, then your router, then your PC.
Make sure your PC can access the Internet. If not, you may need to
configure the router for Internet access. For help configuring the
router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console and sign in with your profile.
If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista - PC with dial-up connection working - Ethernet Cable (RJ45) cable or CROSSOVER CABLE - Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable. 2. Double Click your Dial-up Network connection and wait for it to connect. 3. Choose "Start Menu" and then choose "Settings" then "Control Panel". 4. Select "Network and Internet Connections". 5. Open the "Network Setup Wizard" and then press "Next". 6. On the next screen Ignore the checklist and press "Next" again. 7. Select "This Computer connects directly to the internet." and press "Next". 8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next". 9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next". 10. On the Workgroup screen leave all settings alone and click the "Next" button. 11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next". 12. Now review the settings and click "Next" to apply the changes. 13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard". 2. Select the "System" Blade. 3. Select the "Network Settings" Option 4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Does it say Network Adapter - Disconnected? You tried another cable and still the same thing? When did you purchase your xbox 360? its a possibility that the ETHERNET PORT on your 360 is faulty. might as well contact xbox support to check warranty status of your 360..
Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console with no disc in the disc tray.
If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
if you want to play online, with other people i am assuming? then what you would want is xbox live. you do have to setup a stable internet connection in order to connect to the internet*. and also you do have to pay a membership fee in order to stay in xbox live.
* and if you want to connect xbox live, you need a cable or dsl connection, either you need an ethernet cable or a pre-tuned wireless usb that is made only for the xbox 360. and also, you would need a cable/dsl company that is accepted by xbox live. and then go to the xbox 360 dashboard, then, click "join membership",
Path #2:
setup an ethernet connection either directly, or with a router/hub, then go the system settings, and click, "computers" and then click connect. but this path way is only to create a connection to the computer.
