Question about Lexmark X6170 All-In-One InkJet Printer
Error C50 on Lexmark X6170 printer
Everytime I fill my ink cartridge on my Lexmark printer (X6170), I get a C50 error and cannot print. it's like the printer knows I've refilled the cartridge and gives me an error. Is there any way around this?
  • 5 more comments
  • popa1 May 26, 2008
    first, I would like to be able share my printer with my computer but I lost my soft ware. second when it was working my pinter would not print in color, the message was that, the protective tape was still on the cartiage and it had been taken off. hope you understand this. ED
  • Arnie E Jun 07, 2008
    Same problem. When I load in new cartridges, I get the Error C50 see manual. I misplaced the manual and need a solution
    Error C50 on Lexmark X6170 printer problem, appears when new cartridges are installed
  • Anonymous Jun 08, 2008
    I have not installed a new cartridge, and am getting the 50C error. I then tried to install one, and the same thing happens. How can I get the machine to work? How can I reset this error, or whatever?
  • Anonymous Nov 16, 2008
    alinment problem
  • Anonymous Dec 10, 2008
    I have tried new cartridges, same issue.
  • jenaflores May 11, 2010
    i have this same problem with my computer can someone help me please thanx
  • 4,889 Answers
The ultimate permanent fix for the x6170 printer would be to purchase new cartridge snap-down levers (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). If you purchase snap down levers for a Lexmark printer series X5100 or X6100 or Z55 or Z65, the little guide peg inside the snap lever would work with an unmodified 83 and 82 Lexmark cartridge. All Lexmark did for Dell to make the Dell unique, was to put special Dell snap levers on the printer. I considered breaking off the little guide peg on the snap lever, but decided against it as it appears to help hold the cartridge in alignment
Posted on Mar 08, 2008
    President:
  • 2,351 Answers
You correct about that dmattia! Most manufactures put small chips in the ink cartridges. The driver software knows when you have inserted a re-filled "same cartridge". Hence you get an error.
Theres one way around this wall.
Keep at least two emptied cartridges. (Prefered three).
Go ahead & refill them & store them standing up so the nozzle does not dry out. Rotate your replacements. This works with HP's printers. With the HP's printers it's suggested to rotate three cartridges. This should work for Lexmark as well.
Enjoy!
& please vote.
My Lexmark X6170 won't print or partially prints e-mail. Also it won't copy in black but will copy in color? When this happens I get the 0502 error message. Any idea as to what is wrong and how to...
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
I am unable to find color ink for my lexmark x6170. Additionally, are all the inks the same (quality)?
Lexmark X6170 uses these two ink cartridges: -
Black Print Cartridge (18L0032E)
Colour Print Cartridge (18LX042E)
It is highly recommended that you use the original cartridges as the cartridges and ink vary from printer to printer.
However, if you are unable to find the cartridges, you may look for refilling option.
CreativeTECH
Jan 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a Lexmark X6170 and when I try to copy it says "error 50C cartridge error consult manual. I have changed the black cartridge but not the color I don't use color it was working fine . I can find my...
The error is telling you that the color or black cartridge is missing. It's not recognizing one of your cartridges, most probably the new black cartridge. Here's a link to the Lexmark website to guide you on what to do with that problem. http://bit.ly/bkCWPF
Mar 25, 2010 | Lexmark X6170 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
My printer is saying cartridge error and will not print
Try cleaning the contact on both the ink cartridges and the carriage with a cotton swab dipped in alcohol. It that doesn't work, replace the ink cartridges.
May 26, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6570 "out of ink error message"
I have a Lexmark printer too, and after my original Lexmark ran out of ink, I bought some off of eBay (off brand, not original Lexmark ink), and I get the message I am not using original Lexmark ink, and it is not covered by warranty.  There is no way to remove this message, unfortunately.
Color cartridge stopped working.
Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. If that does not work, the nozzles on the color ink cartridge may be clogged with dry ink.
There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means.
It nothing works, replace the color ink cartridge.
Apr 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
All in One Lexmark cannot recognize Color Cartridge
Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. It that doesn't work, replace the ink cartridge.
Mar 30, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 printer shows hardware error 0502 when printing
On the multi function machine there seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
You may have to do this from time to time if the error keep reoccurring.
Mar 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error message - cartridge error 50c will not print
I have a lexmark x6170 with a cartridge error 50c.
Please I need some help!!
Thank you.
May 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
556 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
