Question about Sennheiser Charging Station for BA2015G2 Battery Units w/ AC Adaptor Included Microphone
Laptop battery will not charge
My laptop battery will not charge- I have replaced it with a new battery and after the initial charge that was in the new battery ran down it would not charge back up
The battery information in the power meter shows the battery with o charge and does not show that it is charging.
the charging light on the front of the laptop only comes on for a second then goes out.
  • 1 more comment
  • Burto72 Mar 17, 2008
    I have the same problem with my Compaq presario v3000
    The light blinks on when i first plug the charger in, then in about 2 secs its out.
    I have the battery test program and it says battery is not charging 0% and is damaged. It suggests replacement.
    Ive had this computer for 5 days, Brand new. never actually used before.
  • stbauer92 Dec 25, 2008
    My battery was dead before got a new battery for my Dell Inspiron E1505 today on Christmas and it started off at 50% life and wont charge the only thing my AC charger is doing is saving the life on it. Should I try and get a new charger?
  • elsiemason Apr 02, 2009
    same situation
  • 682 Answers
Try another charger from good brand and same voltage
Posted on Mar 22, 2008
Acer Aspire 5532 battery replacement charged initially, now says it's charging but stays at 0%
If these were both batteries bought online, say eBay... you may have been shipped defective product.
If not, it sounds like the charging mechanism within the laptop is no longer re-charging your batteries. This will require a visit to your local computer repair shop most likely.
Nov 10, 2017 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Pavilion dv7-1174ca -- Plugged in, not charging. Upon initial boot, there is a CMOS message stating that the storage capacity of this battery is low. After boot, I ran the HP Battery Health Check,...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 24, 2010 | HP Pavilion dv7-1468nr Notebook
I can charge my acer for days and the battery will die within min
The Battery is bad and so its not retaining charge, You may need to get a new battery and from an authorised reseller.
Dec 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dell laptop Will not charge, brand new charger still ran on the lil battery charge that was left in it. Wondering if the part that plugs in is loose or what u may think the problem is, thanks alot!
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 23, 2009 | Dell Computers & Internet
Battery not charging
Your Battery is Done.
Get a New One!
(it might be cheap or free if you are still under warranty.....so check up on that, but I'm not sure)
But your battery is dead, It has seen better days.
Apr 21, 2009 | HP Pavilion dv6000z Notebook
Acer shut down
Souonds like you possibly have a bad power supply. Replace the charger and see what happens
Feb 11, 2009 | Acer Aspire 3680 Laptop
ACER ASPIRE 3002WLCI
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Jan 28, 2008 | Acer Aspire 3000 Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
185 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
